Front Panel Motherboard problem.
25 Nov 2008
Hello,
I have managed to connect the leads for the front panel for power, HD, reset, and speaker but I am left over with two cables one saying with the - symbol, and the other the + symbol I have left over on the front panel - MSG - CI - POWER LED.
I am not sure where the + and - cable need to go it would be fantastic if someone could help, I've tried looking through the manual but cant find anything.
If you've connected the power switch, reset switch and HDD activity LED then they're most likely for the power LED.
What case is it?
Does it have a power LED?
Edit:
I'm getting confused now.
How many wires do you have left to connect?
Thanks - I am now having an issue that windows will not boot. It gets to the loading screen, and than restarts. Could this be because I've installed a new motherboard, cpu, and ram?
