Front Panel Not Working (Gigabyte GZ-X2 with K9N Neo Mobo)
Ogs
Ogs
25 Oct 2007
Ive connected everything up correctly (i think) but for some reason the front panel USB ports refuse to work. It uses a big connector to completely cover the USB bits on the motherboard, so i cant get it wrong, but they simply refuse to work. Is it likely the front panel is broke ? How easy are they to replace ?
I had the same problem once with a PC at work, and it turned out the big USB connector you're talking about wasn't pinned out correctly. I had to use a multi-meter to work out which colour did what and move the pins accordingly. Worked fine after that.
Bah nevermind i fixed it, those dozy Gigabyte fools forgot to plug it in at the front...................
