- 30 Oct 2013
Not sure where best to post this so here goes...
If I connect my back-up drive to the front panel USB 3.0 I get a pop up every few minutes as if I keep unplugging it and then re?-plugging it in again.
If I use one of the USB 2.0 sockets it works as it should.
What's the problem here ? Driver issue perhaps...May be the answer to another thread I have going about "should I do a clean install of windows" since swapping out from A88/ AMD mobo.
Current set up - Asus Max Gene Z77 + i5 2550k
