9 Aug 2006 at 23:47 #1 Bolerus Bolerus Associate Joined 7 Jul 2006 Posts 1,054 Location Stoke on Trent at some point front port usb conection has broken, (the white falt bit has come out) is it possible to get a replacement and solder it in, or do i need a new case (or in truth live with out the front port lol)
9 Aug 2006 at 23:51 #2 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,700 Location Leeds Depending on the case you could probably get a new front port setup for it. You can do nothing bar replace the whole port / bank of ports.
10 Aug 2006 at 15:19 #3 lozza lozza Associate Joined 22 Dec 2004 Posts 1,828 Location Southampton, UK What case do you have?
11 Aug 2006 at 13:40 #4 Papa Lazarou Papa Lazarou Associate Joined 28 May 2004 Posts 143 Location Cardiff I have the exact same issue with my USB ports.. I have a older Coolermaster Praetorian. Can you get spare ports for these?
11 Aug 2006 at 14:38 #5 lozza lozza Associate Joined 22 Dec 2004 Posts 1,828 Location Southampton, UK Papa Lazarou said: I have the exact same issue with my USB ports.. I have a older Coolermaster Praetorian. Can you get spare ports for these? Click to expand... Yes you can if you contact coolermaster email [email protected]
12 Aug 2006 at 02:09 #6 Papa Lazarou Papa Lazarou Associate Joined 28 May 2004 Posts 143 Location Cardiff Many thanks mate. Its just one of those things thats bugged me for a while. Will be glad if it can be fixed easily.
