Front Row Missing?
14 Apr 2004
UK
I was experimenting a few nights ago and I managed to corrupt my windows install and Tiger woulnd't boot up.
So I went for an Archive and Install option. It retained everything bar Front Row. I can't seem to find it.
Cheers.
Al Vallario said:
You said you "can't seem to find" Front Row, but how would one usually find Front Row in the UI? The only way I can find it is using the remote! :o
Command + ESC tbh.
It's not showing up on with my remote either.
