Front usb bus not working.
20 Jul 2010
As in the tittle the 2 USB ports on the front of my antec 300 case arent working. However the headphones and mic work as does the on/off switch. So is this just a driver issue? And if so where should i look for drivers? thanks in advance for the help :D
Check that they are the correct way round, that the cable isnt for firewire instead, and that they are enabled in the BIOS.
Pretty sure the wires are in the right place (or would hope so) since it was the ocuk guys who built it lol. I suspect its the BIOS thing more likely. Any chance you could put a bit more detail down on enabling them in the BIOS. would be sexy times!
x
Ah dumbass me didnt check properly earlier. The USB head was connected into the firewire on the mobo. Changed it and all fixed :D
I say off with the head of whoever put that cable in!
