Frustrating 360 problem
18 Oct 2006
Got a 360 about a month ago and have played around 5 games to death, got loads of achievements etc...tonight I decided to signup to XBOX live but my offline username was taken so made a new one, assuming that all my in game achievements and so on would be moved over to the Live Gamertag...not the case, now I have my Live ID and my offline ID...the latter having all my achievements and frankly, i don't want to have to do it all again, anyway of moving them over to my Live tag?
You already paid for the sub?
If not change the offline ID to an available name you want then log on with that one.
You could try deleted the onlineID ; then rename the offlineID to the onlineID and try to connect?
/edit
id suggest backing up profiles first :)
that how i did my mates
his offline one was "bcUK" - and we signed up online for "ThisName"
so i renamed the offline one to "ThisName" then used Recover Gamertag iirc
I've tried renaming the offline one to my online one but it won't allow me to because the online one already exists on the hard drive...can't find a function to delete the online profile anywhere?
under Memory management in the system blade
I currently have the same problem,
I deleted my "live" profile,
renamed the "local" one to my "live" name,
went through "recover tag" and..
nothing, just comes up with 0 achievments. begger
I'm not so bothered about the achiements, more the game saves etc - am I doing the right thing to move these across as well ?
EDIT: Fixed it
http://www.xbox.com/en-US/support/systemsetup/xbox360/accessories/harddrive.htm
To copy or move an item from your hard drive to a connected device:
1. With the hard drive attached to the Xbox 360 console, turn the console on.
2. Go to the System area of the Xbox Dashboard and select Memory.
3. Select your hard drive.
4. Select the category of the item you want to copy or move.
* To copy or move videos, trailers, and demos, select either Videos and Trailers or Demos, then select the item.
* To copy or move gamer profiles, gamer pictures, and themes, select either Gamer Profiles, Gamer Pictures, or Themes, select the owner of the item, then select the item.
* To copy or move all content associated with a game, select Games, select the owner of the content, choose the game, select Game Options (Y), then select the item.
* To copy or move just one item for a game (such as a single saved game), select Games, select the owner of the content, select the game, then select the item.
