update - found the error log on another forum from someone with the same problem:
GetDXVersion() failed.
[01/29/07 20:53:34] module: DXWSetup(Dec 8 2006), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
DirectXUpdateDownloadPlugIn() failed.
[01/29/07 20:53:34] module: DXWSetup(Dec 8 2006), file: psheets.cpp, line: 498, function: PreinstDlgProc
[01/31/07 10:50:22] module: dxupdate(Dec 8 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
Failed API: RegQueryValueEx()
Error: (2) - The system cannot find the file specified.
Current DirectX may be a older version which does not have the version value in the registry.
[01/31/07 10:50:22] module: dxupdate(Dec 8 2006), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[01/31/07 10:50:23] module: DXWSetup(Dec 8 2006), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[01/31/07 10:50:23] module: DXWSetup(Dec 8 2006), file: psheets.cpp, line: 498, function: PreinstDlgProc
[02/07/07 16:39:18] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[02/07/07 16:39:18] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[02/07/07 16:39:19] module: DXWSetup(Jan 24 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[02/07/07 16:39:19] module: DXWSetup(Jan 24 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[02/13/07 18:29:51] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[02/13/07 18:29:51] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4718, function: DirectXUpdateGetSetupInformation
[02/13/07 18:29:51] module: dsetup32(Jan 24 2007), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
DirectXUpdateInstallPlugIn() failed.
[02/13/07 18:29:51] module: dsetup32(Jan 24 2007), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[02/16/07 22:37:38] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[02/16/07 22:37:38] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4718, function: DirectXUpdateGetSetupInformation
[02/16/07 22:37:38] module: dsetup32(Jan 24 2007), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[02/16/07 22:37:38] module: dsetup32(Jan 24 2007), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[02/16/07 22:41:09] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[02/16/07 22:41:09] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4718, function: DirectXUpdateGetSetupInformation
[02/16/07 22:41:09] module: dsetup32(Jan 24 2007), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[02/16/07 22:41:09] module: dsetup32(Jan 24 2007), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[02/17/07 12:37:43] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[02/17/07 12:37:43] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[02/17/07 12:37:44] module: DXWSetup(Jan 24 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[02/17/07 12:37:44] module: DXWSetup(Jan 24 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[02/22/07 18:07:05] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[02/22/07 18:07:05] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[02/22/07 18:07:06] module: DXWSetup(Jan 24 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[02/22/07 18:07:06] module: DXWSetup(Jan 24 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[02/26/07 15:50:40] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[02/26/07 15:50:40] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[02/26/07 15:50:41] module: DXWSetup(Jan 24 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[02/26/07 15:50:41] module: DXWSetup(Jan 24 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[03/03/07 19:47:12] module: dxupdate(Feb 3 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/03/07 19:47:12] module: dxupdate(Feb 3 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/03/07 19:47:12] module: dsetup32(Feb 3 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/03/07 19:47:12] module: dsetup32(Feb 3 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[03/03/07 19:50:24] module: dxupdate(Feb 3 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/03/07 19:50:24] module: dxupdate(Feb 3 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/03/07 19:50:24] module: dsetup32(Feb 3 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/03/07 19:50:24] module: dsetup32(Feb 3 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[03/03/07 19:52:12] module: dxupdate(Feb 3 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/03/07 19:52:12] module: dxupdate(Feb 3 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/03/07 19:52:12] module: dsetup32(Feb 3 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/03/07 19:52:12] module: dsetup32(Feb 3 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[03/05/07 20:56:00] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/05/07 20:56:00] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[03/05/07 20:56:01] module: DXWSetup(Jan 24 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[03/05/07 20:56:01] module: DXWSetup(Jan 24 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[03/05/07 21:05:48] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/05/07 21:05:48] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[03/05/07 21:05:49] module: DXWSetup(Jan 24 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[03/05/07 21:05:49] module: DXWSetup(Jan 24 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[03/10/07 22:06:38] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/10/07 22:06:38] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[03/10/07 22:06:39] module: DXWSetup(Jan 24 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[03/10/07 22:06:39] module: DXWSetup(Jan 24 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[03/10/07 22:26:49] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/10/07 22:26:49] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/10/07 22:26:49] module: dsetup32(Mar 31 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/10/07 22:26:49] module: dsetup32(Mar 31 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[03/10/07 22:29:02] module: DXSetup(Mar 31 2006), file: dxsetup.cpp, line: 934, function: FindDXSetupWindow
Failed API: GetWindowText()
Error: (183) - Cannot create a file when that file already exists.
[03/10/07 22:32:10] module: DXSetup(Mar 31 2006), file: dxsetup.cpp, line: 934, function: FindDXSetupWindow
[03/10/07 22:32:33] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/10/07 22:32:33] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/10/07 22:32:33] module: dsetup32(Mar 31 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/10/07 22:32:33] module: dsetup32(Mar 31 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[03/10/07 22:33:00] module: DXSetup(Mar 31 2006), file: dxsetup.cpp, line: 934, function: FindDXSetupWindow
[03/10/07 22:33:24] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/10/07 22:33:24] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/10/07 22:33:24] module: dsetup32(Mar 31 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/10/07 22:33:24] module: dsetup32(Mar 31 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[03/10/07 22:33:40] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/10/07 22:33:40] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/10/07 22:33:40] module: dsetup32(Mar 31 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/10/07 22:33:40] module: dsetup32(Mar 31 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[03/10/07 22:37:16] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/10/07 22:37:16] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/10/07 22:37:16] module: dsetup32(Mar 31 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/10/07 22:37:16] module: dsetup32(Mar 31 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[03/10/07 22:37:34] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[03/10/07 22:37:34] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[03/10/07 22:37:34] module: dsetup32(Mar 31 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[03/10/07 22:37:34] module: dsetup32(Mar 31 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[04/03/07 16:46:30] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[04/03/07 16:46:30] module: dxupdate(Jan 24 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[04/03/07 16:46:31] module: DXWSetup(Jan 24 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[04/03/07 16:46:31] module: DXWSetup(Jan 24 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[04/03/07 16:57:30] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
[04/03/07 16:57:30] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
[04/03/07 16:57:30] module: dsetup32(Mar 31 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[04/03/07 16:57:30] module: dsetup32(Mar 31 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[07/24/07 17:28:11] module: dxupdate(Jun 20 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[07/24/07 17:28:11] module: dxupdate(Jun 20 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[07/24/07 17:28:12] module: DXWSetup(Jun 20 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[07/24/07 17:28:12] module: DXWSetup(Jun 20 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[07/26/07 17:33:34] module: dxupdate(Jun 20 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[07/26/07 17:33:35] module: dxupdate(Jun 20 2007), file: dxupdate.cpp, line: 4504, function: DirectXUpdateDownloadPlugIn
[07/26/07 17:33:36] module: DXWSetup(Jun 20 2007), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[07/26/07 17:33:36] module: DXWSetup(Jun 20 2007), file: psheets.cpp, line: 498, function: PreinstDlgProc
[07/26/07 17:40:22] module: dxupdate(Jun 20 2007), file: dxupdate.cpp, line: 189, function: GetDXVersion
[07/26/07 17:40:22] module: dxupdate(Jun 20 2007), file: dxupdate.cpp, line: 4740, function: DirectXUpdateGetSetupInformation
[07/26/07 17:40:22] module: dsetup32(Jun 20 2007), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[07/26/07 17:40:22] module: dsetup32(Jun 20 2007), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[04/21/08 18:17:48] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 175, function: GetDXVersion
Failed API: RegOpenKeyEx()
Current DirectX may be a older version which does not have directx key in the registry.
[04/21/08 18:17:48] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 4515, function: DirectXUpdateDownloadPlugIn
[04/21/08 18:17:49] module: DXWSetup(Mar 5 2008), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[04/21/08 18:17:49] module: DXWSetup(Mar 5 2008), file: psheets.cpp, line: 498, function: PreinstDlgProc
[04/21/08 18:21:10] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 175, function: GetDXVersion
[04/21/08 18:21:10] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 4515, function: DirectXUpdateDownloadPlugIn
[04/21/08 18:21:11] module: DXWSetup(Mar 5 2008), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[04/21/08 18:21:11] module: DXWSetup(Mar 5 2008), file: psheets.cpp, line: 498, function: PreinstDlgProc
[04/21/08 18:24:36] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 175, function: GetDXVersion
[04/21/08 18:24:36] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 4515, function: DirectXUpdateDownloadPlugIn
[04/21/08 18:24:37] module: DXWSetup(Mar 5 2008), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[04/21/08 18:24:37] module: DXWSetup(Mar 5 2008), file: psheets.cpp, line: 498, function: PreinstDlgProc
[05/08/08 17:57:50] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 175, function: GetDXVersion
[05/08/08 17:57:50] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 4515, function: DirectXUpdateDownloadPlugIn
[05/08/08 17:57:51] module: DXWSetup(Mar 5 2008), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[05/08/08 17:57:51] module: DXWSetup(Mar 5 2008), file: psheets.cpp, line: 498, function: PreinstDlgProc
[05/13/08 15:59:19] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 175, function: GetDXVersion
[05/13/08 15:59:19] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 4515, function: DirectXUpdateDownloadPlugIn
[05/13/08 15:59:20] module: DXWSetup(Mar 5 2008), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[05/13/08 15:59:20] module: DXWSetup(Mar 5 2008), file: psheets.cpp, line: 498, function: PreinstDlgProc
[05/13/08 16:01:21] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 175, function: GetDXVersion
[05/13/08 16:01:21] module: dxupdate(Mar 5 2008), file: dxupdate.cpp, line: 4515, function: DirectXUpdateDownloadPlugIn
[05/13/08 16:01:22] module: DXWSetup(Mar 5 2008), file: dxupdate.cpp, line: 386, function: DownloadPlugIn
[05/13/08 16:01:22] module: DXWSetup(Mar 5 2008), file: psheets.cpp, line: 498, function: PreinstDlgProc
