- 29 Sep 2004
- Newcastle upon Tyne
Please bear with me as this is quite a long story...
Was running a Gigabyte GA-P35C-DS3R, Dual Core E6420, 2Gb Geil PC6400 and a Gainward 6800 GS. Everything was working fine until just before Christmas it decided to switch itself off and wouldn't switch back on again. As there were no lights on the motherboard I guessed at either PSU or Mobo failure. I tried a spare PSU and there was no difference so decided it must be motherboard.
As I was going to have to rebuild I decided to add another 2 Gb RAM, replace my IDE DVD for a Sata, and buy a new case.
This time went for an Asus motherboard, the P5KC Combo Intel P35.
This was built with my original processor, graphics card and the 4 x 1 Gb memory in a new Antec P190.
Everything fired up first time, Windows installed cleanly and all was good until about a week later when it started to show a reluctance to reboot - sometimes taking up to 10 times before it would fire up.
Decided that maybe the processor had been damaged when the mobo went (was reporting very low CPU temperatures) so bought a 6750.
Stripped everything out, put new processor in, and it fired up first time again. Everything seemed to be working fine.
Fast forward 3 days when I install a bit of software that needs a reboot, and it decides it doesn't want to start up again.
Symptoms are:
On switch on the HDD activity light flashes on, the DVD drive spins to see if there is a disk in the drive, then nothing - don't even get a BIOS screen.
All that's left of my original machine is the graphics card, but I'm reluctant to spend even more money if that's not the cause.
Anyone got any ideas?
Symptoms are:
