I have my E6600 happily sitting @ 3.2 on an Asus P5N32-E Plus Sli.
But in my quest for 3.4Ghz i have hit a problem in that anything above the 1422 QFSB i used to get there my mobo will not post and requires me to reset the CMOS using the jumpers. No ammount of voltage increases on either the Vcore/Mem/NB will let me post. Memory doesent seem to be a problem i have GeIl 800Mhz C4 which runs unlinked @ up to 900Mhz.
While OC'ing to 3.2Ghz if it wasnt stable or a bad OC i could get it to post but Bios flashed up sayig incorrect setting and i needed to reset to defaults. But i get nothing when trying above 1422QFSB.
Is this because i hae found a FSB hole? Does anyone have any ideas how to work aroud this? Possibly a much higher QFSB and lower the multi?
Have tried reading up on my board but have found the threads either so massive that finding relevent information is tricky or ambiguous at best.
) updated bios and got no problems going higher at all
- E6600 + P5B Deluxe
