FSB Strap To NorthBridge?
11 Jun 2004
Middlesex, London
Hi all,
I'm testing out an Asus P5K
What is this setting please? What should I set it to?
Thanks
Leave it on auto and set the ram to run at it's correct speed from the drop down list under Dram Speed. That's what i always do on my P5E.
FSB Strap does two important things:
  • Offers different memory dividers
  • Changes the latency of the Northbridge (tRD)
I'm finding the overclocked computer is running loads faster after manually setting the FSB strap to 200 and selecting the 2:1 divider, you will need pretty fast memory to select the latter.
If you select the lower FSB straps (200/266) while running a very high FSB you may need to give the northbridge some extra juice (vNB) to keep everything stable
