** FSP POWER SUPPLIES INCOMING **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Gang
We have a new brand entering the OcUK power supply range today.
FSP are a global leader in power supply manufacturing. They produce units as an OEM for some of the largest brands you will have already heard of.
There is a high chance that the PSU in your PC currently is made by FSP!
The brand has overhauled their current range offerings and we are launching a small, focussed selection of higher performance models from them that cater for performance hardware users.
As many of you know, the budget and mid range power supply market currently is packed with great options at super aggressive price points. With that in mind, we have taken a range which is geared more towards the hardware connoisseur.
FSP are well known for their superb quality, excellent efficiency ratings and reliability. All of the units in our range showcase excellent performance with strong voltage regulation figures as well as a host of protection features to safeguard your components.
All of the units in our range also feature a 10 Year Warranty.
I have purchased thousands of PSUs from FSP throughout the years and can personally attest to the reliability of the products FSP produce.
FSP HYDRO PTM PRO
80+ Platinum efficiency rated units with fully modular cables, loads of safety protection features and of course, ATX 3.1 PCIE 5.1 compatibility.
FSP VITA GM
80+ Gold rated fully modular supplies offering stable and efficient power. Meeting the latest standards at offered at lower wattages than the HYDRO PTM range.
FSP Dagger PRO ATX3.1
High efficiency 80+ Gold rated SFX unit with a great feature set and offering good value for SFF builds that need solid, reliable power from an SFX format unit.
Always nice to see 10 year warranty PSU's. Where is their RMA centre or do you handle the returns for the full 10 years?
they have a UK distributor who we work closely with.
In terms of RMA, I have always had good experiences with them when managing their products. I used to use them in my systems range when I worked elsewhere and the failure rate was incredibly low. RMAs were handled in a timely manner too. No different to any other major brand really but that was a big factor for me bringing them into our range at OcUK.
Was looking at the 850GM, it looks smart and well made, also looks like the FSP text on the right side in the pic below is done in the same colour as a couple of the capacitors inside... which I love!
Never heard of FSP but Planning on an Intel build and tempted to use one of these.
Ok wow, FSP is really a blast from the past. But yeah, they did make well regarded PSUs for their price. Didn't they become Sparkle for a while, also well regarded?
Today we are kicking off a discount on the FSP VITA-850GD 850W power supply.
This is a 80+ Gold rated non modular supply with all the latest standards. Usually at £109.99 MSRP, we have limited stock available for £83.99 making this one of our best value 850W units currently on offer at OcUK.
Not only is the VITA-850GD a solid PSU at a storming price point, but the VITA models are compact at only 140mm in length making them a little shorter than a typical higher wattage unit. This makes the VITA a strong option for smaller cases that dont have the room to accomodate longer power supplies.
The deal will be running from now until the stock is gone :cool:
I like having a spare psu. they do eventually degrade - I have had one that started to lose power and I had to start disconnecting drives etc. Nowadays I buy better quality psu and ones with a higher wattage than I need at the time (even more important if I am going to upgrade my gpu as the new gpus seem to be much more power hungry).
