FSX Performance.
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
I've just been playing FSX, and close to the ground it felt choppy, or like stuttering, is this normal?
Also for a system like mine:
HD2900XT
E6600 @ 3.4Ghz
2GB Crucial Ballistix ram.
What settings should I have it set to so that I can be sure I get smooth gameplay.
Thanks
Willz.
FrannoBaz said:
update the game to Service Pack 1
Ok will do.
Are you able to run the game at max settings? I dont know what settings to choose to make the graphics look the best or what mods I need to apply for better land, all these options, jesus its like the starship enterprise.
The main thing to turn right down is AI traffic - that seems to grind mine to a hault. And that's with a reasonably good system e6600, 4gig DDR2, 8800gts. Everything else is maxed at 1680x1050 apart from ground shadows and the bloom thing
