FT02 FFFFUUUUU
20 May 2011
Aberdeen, Scotland
Hey guys.
Was just chillin with tunes with my Senn's plugged into my headphone port, and then stood up, tripping over the headphone cable (SENNHEISER Y U MAEK HEADPHONE CABLE SO LONG?!) the cable came flying out of the Grado lead I use to convert it to a standard jack size. Upon plugging back in, I discovered I totally ****ed the headphone port by doing that.
So uh, does anyone know where to get that entire i/o bit replaced? (2xUSB, mic and headphone port)
(Silverstone FT02 if you didn't realise by the title)
Edit: Found it. With bonus USB 3.0 too!
Silverstone G11303260 USB 3 I/O Port
why on earth are you using good headphones on a crappy front panel connector ? plug them directly in to the soundcard
The power button on my case didnt work when i recieved it, they wanted to charge me quite a lot to replace it. Turns out i could fix it by opening up that top panel and pushing some bit sback onto position and supergluing it.
Could you do that?
These headphones are my HD595s, and at the time I was using them to switch from PC to TV, so had it in the front port for convenience. And I don't have a proper sound card, just the MB one. Was going over budget so decided not to include one since I didn't have HD650s or anything like that.
I do collect all my music in FLACs though for when I finally do get HD650s and proper equipment. :D
Could you do that?
Nah, it's okay though, once the USB 3.0 ones are back in stock I can order that and replace it. It'll be an upgrade anyway since the ones I currently have are USB 2.0.
