Hello folks,
I'm in a bit of a situation with a house I've had an offer accepted on, in regards to the age of the roof. The house was built in the 30s
The home buyers report (by countrywide) states;
Now the vendors have a letter from a local building services company which says;
This got rejected by Accord, the mortgage company for going against what the home buyers report said and also having no date on the letter ! (not to mention the address was incomplete)
Accord say I can't get a mortgage until they have a quote for the roof replacement work, even then there will be a retention on the mortgage until the work is done.
Estate agent has been less than helpful, I'm trying to get a roofer who came recommended to me to have a look at it and give a quote.
Anyone had this before? Would my solicitors be able to help?
Cheers!
The main roof covering is double pitched and hipped with a covering of asbestos cement tiles. No excessive deflection was noted in the roof slopes. This does not have a secondary waterproof barrier (roofing felt). The covering is at the end of its useful life and should be replaced now. Because of the possible asbestos content, you should get advice from a contractor experienced in this type of work or an asbestos specialist before the covering is disturbed in any way. Renewing the roof covering will require Building Regulation approval and, depending on the type of tile selected, strengthening of the roof structure may be required.
After examining the roof, the only repair required is a small amount of pointing on the hip ridge tiles. This repair could be rectified for £175
Cheers!
