FTP Help, please.
30 Jul 2004
East Sussex, UK
Howzit Guys.
I've setup a small FTP server at home. However I am having a small problem.
I want to be able to access the FTP Server via WiFI and over the LAN. Lan for me as it's faster to my machine.
Now at the moment, I am using FilleZilla as an FTP server as it works very well.
At the moment, if I want to use the LAN connection to access it I have to go into the settings of the server, then change the IP address to, 192.168.2.100 (This is for my LAN connection) After doing this, my WiFI connection no longer works, (10.0.0.113). :(
It does say, I must type in, '*' to bind all IP addresses however all this command manages to do, is disconnect me completely from the server, making both IP address useless. :mad:
So, how else can I get BOTH IP addresses to work?
Many thanks
Any help, will be much appreciated! :cool:
