- 11 Mar 2008
Since I put my new build together, I've had a couple of instance where on bootup I get a BIOS message reporting:
I can press Y to reset the fTPM and lose access to all encryption mechanisms using it, or press N to keep previous fTPM record and continue system boot.
Pressing N just loops and repeats, so the only way to continue is to press Y and reset it. Thankfully I've not used anything that uses TPM, I only enabled fTPM out of curiosity when the new that Win11 will require it but this does seem to be fundamental problem should Win11 actually use it for something.
I've got a 5900x with a Gigabyte x570 Aorus Ultra - I've not replaced the CPU at all, nor have a I don't anything to change fTPM settings (not that I'm aware of anyway), so I'm assuming that the fTPM has corrupted. Does anyone know if this is an issue with fTPM in the CPU, or a problem being caused by the MB?
Code:
New CPU Installed, fTPM/PSP NV corrupted or fTPM/PSP NV Structure change
