As per the title my exchange is due for FTTC in March 2012. I live in a village at the very limit for ADSL (You are approximately 4.70km from the exchange) so I'm really hoping that BT will run fibre to the local CAB which would be great, however as this is BT I expect they won't due to return on investment. Is there anyway to find out which cabinets will be done as part of the process? The exchange is Alfreton
If I run a SamKnows against my Tel + Postcode I get the following;
BT FTTC broadband availability
You are connected to the Alfreton telephone exchange.
FTTC should be available in your area from 01/03/2012
Downstream Min: 15.8 Mbps
Downstream Max: 28.2 Mbps
Upstream Min: 2.2 Mbps
Upstream Max: 11 Mbps
Is there anyway to get this info from BT?
Any advice appreciated
- trust it to me or post it on here
