Hi All,
I'm hoping to look into getting FTTC (fibre) from BT in the New Year. I understand that BT have to replace the fascia of your master socket with a new sffp faceplate, which includes the normal BT socket for the phone, and then a filtered RJ45 (or possibly RJ11) connection at the top. I then understand that you connect a cat5 cable from the top of the sffp face plate to a BT branded "modem", which in turn presents out on RJ45 (Cat5e) to your PPPoE router (which needs an RJ45 WAN port).
Unfortunatly for me, I have to have my current ADSL router upstairs on an extension socket (the master socket is downstairs in living room). I understand BT can provide a 30M extension kit if required (which is basically a CAT5e cable from the master socket to the modem/router).
I can't really see how I can do this cable run in my house, so does anyone know if you could use powerline bridges (the units which run ethernet over your electrical ring main) to take the connection from the SFFP mastersocket direct to the modem and router which I would wish to still have upstairs OR maybe I would need to have the BT provided "modem" downstairs direct into the sffp main faceplate, and then run the RJ45 presented from the "modem" into the powerline, which could then connect up to me PPPoE router upstairs ?
Has anyone successfully used Powerline devices with the new FTTC technology ?
Thanks
Thanks
