- 9 Jun 2011
Hi folks getting ultrafast fibre 300. Anyone know how good the included router is ?
What can I expect for the installation
Hi it's bt, they have my go live date on the 4th but will send engineers out on 25th to install a box ??Depends who your ISP will be as to what router you'll get. Who is it?
Just good signal tbh have 3 floors in home so might get their mesh but it's a fiver per month...You'll get a Smart Hub 2, which I've never had a problem with.
Are there any specific features you feel that you need?
Wifi on BT's routers is s***. A cheap £40 TPLink gives better signal than the Smart Hub.
