Fuji FinePix S5600 Focus issues..
12 May 2005
I’m hoping someone can give me a bit of free advice. I’ve read and search around in this section of the forum, appears to be some very gifted and knowledgeable digital camera users hanging about in here, so I’m hoping someone can just at least give me some good advice.
I’m really struggling to get to grips with a recent camera purchase. I’ve just got a nice deal on a Fuji Finepix S5600 Zoom. It came with a 512MB xD card, and 2500 re-chargeable batteries. The camera wasn’t cheap, maybe a cheap camera for some of the SLR crew, but for me I felt it to be a lot of money. £174 for a camera means I want to learn all I can, problem is, I can’t even get to grips with the basics, never mind about anything more “artistic”. The camera was purchased from a shop I won’t name, but they are not the most honest. I read many reviews, and was impressed with what I read about this model, and when I called the shop I purchased it from, I was assured it was a UK model. It is not. I’ve not got a English manual, a problem I’ve managed to overcome by downloading the PDF file from Fuji US, and not Fuji UK as they will not support the camera, as it was not a UK model.
Anyhow, my main purpose for this camera is to take pictures of small objects upclose. Think, little scale models, but I also wanted to take some nice landscape pictures, and family pictures. Bascially a camera that works well for up close, and for everything else.
I know this is hard to archive with a single fixed lens camera, but the results I’ve been getting with this unit, have, quite frankly been a massive disappointment. I took some pictures of docklands the other day, when at the UK motor show, and when compared to the camera my GF was using, they don’t compare at all. Mine are all washed, lack colour, or not sharp. I used mostly Autofocus, and zoomed in on a tall building, using many different modes to try it out.
The other camera was a CAMEDIA C460, just point and shoot, and the pictures, are IMO much better then what I got with this “meant” to be better camera.
Now upclose pictures are a whole new ball game. I can’t get the macro to focus. You press the shutter button down to focus, and using the zoom on my tripod to zoom in from a distance never gets me a focus. I try using A mode, upping the F number, try fast shutter, auto shutter, auto modes. It won’t focus any closer then what looks to be a foot away when compared to the C460.
So, anyone got a 5600 and care to share how I get the camera to focus up close, using macro mode? Some one mentioned that I should perhaps get a macro lens, then I was told to read about DOF, and get the aperture right. Outside is where I’m trying this out, I use auto white balance, and my pictures are not good. They look over exposed sometimes. Yet if I try and change the exposure, they just go too dark. I use 100 ISO, sometimes 200 when outsite, inside I’d use 400. Try and use a home made flash box to get light, but I prefer to work outside when taking pictures as sunlight is free, and a good source of light.
I’m sure I’m doing something wrong. 8 days now, of trying to use this camera, and I’m not impressed. I’d be really grateful for some help…. I know you can’t teach me to take my own pictures, but any advice on how to set this camera up would be welcome. I thank you for your time in reading this…
I don't have a 5600 but I do have a 9500. Mine miss-focuses occasionally. It would be best if you could post examples of the images you are not happy about so we can try to determine what went wrong, it could be any number of things. A lot of the time poor image quaility is down to user error rather than faulty equipment.
Hmm, you may have chosen the wrong camera then. I know the macro facility on the 9500 isn't great. Make sure you are not too close to the object for the camera to focus. Stick the camera on a tripod, make sure you get focus lock and take some test shots. Any slight hand movement will have a noticable effect on macro image quality unless got can get a fast shutter speed.
When zooming right in on a building you will need to use a fast shutter speed to get a sharp image. If your zoom is 300mm then you will need to use a shutter speed of 1/300 or faster to get a sharp image (generally speaking). If you were using it indoors, with no flash, at the telephoto end, it's quite possible the shutter speed was too low to get a sharp image. Another thing to bear in mind is the sharpness of the lens might not be great at the extreme telephoto end of the zoom, I know the s9500 isn't great at 300mm.
Can you post a sample of similiar scenes taken with both cameras?
I can’t get the macro to focus. You press the shutter button down to focus, and using the zoom on my tripod to zoom in from a distance never gets me a focus. ... It won’t focus any closer then what looks to be a foot away
Using the telephoto end of the zoom in macro mode, will mean you will have to move futher away from the objec to focus. Can you get a focus lock in macro mode at the wide end? I think you can get a 3rd party macro add-on that will allow you to get closer. You may loose some image quality but it might suit your needs.
Before writing off the camera, try using it in AP mode at around f5.6 to F8, at around 50mm or less in bright condiotions, make sure your shutter speed is not to slow (you might get a warning preview in the EVF if the shutter speed it to low to hand hold) see how those images are.
Got a S9500 myself.
I'm pretty happy with the Macro facility it has. Better than my Canon A80.
http://www.flibster.com/Images/Wildlife/Dragonfly_Small.jpg
Ok - not a true Macro but surprised me, especially as it was hand held.
I would definately get a good tripod and a cable trigger *if the S5600 supports it* Also avoid using the zoom while in macro mode, keep it as close as possible.
As for the shots being washed out. White balance may be off.
Simon/~Flibster
Hi all..
Thanks for the answers, I couldn't work this camera, so managed to speak with a friend of a friend at work and a guy who does SLR for a part time living gave me some help last night. He got it to focus VERY close and told me how to use macro mode.
The closer the better, and no zoom hardly, using a tripod he gave me last night as well... Stunning camera in the right hands.. Couldn't believe the pictures he was pulling off it. Wonderful blurs he was getting, told me its a good camera and to stick with it. Its like SLR just fixed lens. Said the zoom was very good, and macro is fine for the type of work I needed it for, but not to use zoom in macro as it's not all that good with macro zoomed shots. He explained how to focus, use or slow shutter for low light, using the ISO modes and how they affect the picture. I learnt a lot from him last night, was a good time to get to grips with it..
Sadly, it was me.. Still got to learn how to do this myself, but it was comforting to know I'd not wasted my money.
He also got the manual modes to focus as well, but he said that was a bit tricky, and I was best to stick with AF on this model...
Thanks all...
Hi
Glad you have got it all sorted out, don't worry about it 'being you', we all start from somewhere (I know I still have a cupboard full of blurred shots) you will improve as you go along.
My main worry is that the camera is a 'grey import' if it's not a genuine UK stock item. That means if it goes wrong and you take it back to the shop to have it repaired Fuji UK might just say "No, you have to take it back to the country of purchase" - obviously this is to stop people buying cheaply abroad.
I suppose you would be fine as it is covered by a 12 month warranty with the shop rather than Fuji but if they are less than honest I think I would like in writing that they will honour any warranty claims for the first 12 months.
Maybe I am being a little alarmist but deceiving a customer just to get a sale sets alarm bells ringing for me...certainly I would have never done when I was in camera sales.
Hi,
Yes, I’m not very happy with said company. They have offered to give me a 12 month warranty but only if it goes wrong will I see how “to their word” they really are. They lied to sell me the camera in the first place, something I’m already complaining about, and as yet have heard nothing back on, so in terms of equipment I’m now very happy, but in terms of sales I'm less then pleased.
It’s my first expensive camera, the stepping stone towards learning a great deal about this wonderful little hobby, after last night and seeing what can be done, I’m keen to learn more. However the company I purchased the camera from are a very deceitful company, and they shall never see anymore of my money again.
I could have gone to ebay and got a grey import for less money, so I knew they were out there and this was the reason I asked. Typical UK service.
Thanks all…
