fuji s9600
19 Feb 2008
Home
Has anyone got one of these fine camera's ?
Are they as good as the reviews ?
just looking for a good camera for some good shot's mainly of my daughter and place's we visit.
just wanted to know if anyone has got one and how they get on with it.
Many thank's in advance.
dont worry ive ordered one.
£214 with free delivery,free 2gb cf card,free bag,free tripod and 2 year warranty.
thought that was a good deal.
I will assume it is a much better camera than the Fuji s5500 i have just updated from and that was a fine camera for what i wanted at the time.
i wanna know if its worth it as an upgrade from my Ricoh r7 compact, going to scotland soon and dont wanna miss out on the scenery :)
www.fujifilm.co.uk There’s a well-known saying that ‘if it ain’t broke, don’t fix it’ and that’s exactly the approach Fujifilm took when it upgraded the S9500 to create the FinePix S9600. But have they taken this sentiment a little too far? According to the manufacturer its ‘carefully chosen’ improvements seem to amount to little more than a larger LCD screen and a few tweaks to the processing algorithms. So has this been a fruitful excercise and what exactly does the S9600 have to offer? Features Like the S9500 there’s a 1/1.6in 9mp Super CCD sensor at the back of the S9600 and a fixed, 10.7x zoom up front covering 28-300mm focal length equivalents with an f/2.8-4.9 maximum aperture. We're slightly disappointed that some form of optical image stabilisation hasn’t appeared this time round, as a 300mm focal length could benefit from it, but Fuji has always preferred to utilise high ISO settings to give you a fast shutter speed for shake-free images. In this instance the range runs from ISO 80-1600. In terms of photographic controls it’s hard to find fault, with the S9600 incorporating all the shooting modes you’re likely to find on an entry-level DSLR, so we get automatic, PASM and a selection of preset scene modes. These are backed up by 256-segment multi-area, centreweighted and spot metering patterns. Both Raw and JPEG capture is possible, with dual card slots allowing you to record to either CompactFlash or xD media. Equally impressive are the ‘little things’, such as a PC sync socket to connect external flash units and a threaded shutter release button to accommodate an inexpensive cable release – try finding those on an entry-level DSLR. You are also able to compose your images on the rear LCD if you choose to, while the mirror-less bridge camera design also lets you record movies with a 640x480 pixel resolution at a rate of 30 frames per second – again not possible with a DSLR. So, while it may not be a major advancement on the S9500, in terms of its photographic features the newcomer manages to offer the same functionality as an entry-level DSLR and, arguably, a little more besides. Design With its compact, DSLR-style body the S9600 sits comfortably in the hand while the nicely proportioned grip provides a firm hold on the camera. The controls are also cast very firmly in the DSLR mould, with a top-mounted mode dial, top / rear control wheel and a smattering of buttons on the back and left sides. We do find that the interface isn’t as intuitive as it could be, though, and despite the number of buttons on the outside, useful parameters such as white balance and AF have been ‘hidden’ in the multi-layered menu system. While the ‘F’ (function) button quickly gets you to the ISO and image quality options I would say this should be where white balance is found too. It’s also rather odd that Raw capture is ‘buried’ on the second page of the set-up menu and not listed as an image quality option – but maybe that would be too obvious? Yet once you’ve accepted that changing settings isn’t as straightforward as it could be, it isn’t all-bad and the flip-out LCD is a boon for low-level shooting or taking candid shots ‘from the hip’. However, the increase in the LCD size from 1.8in on the S9500 to 2.0in in the S9600 seems rather inconsequential and compared to the 2.5in screens used by most DSLRs it’s decidedly mediocre. Performance Improved low-light AF performance is one of the S9600’s key improvements, and remembering the S9500’s rather lacklustre capabilities in this area, the new camera is certainly better. Near-to subjects are brought into focus with relative ease using the AF assist lamp, while subjects a few metres away can be brought into sharp relief given a moment or two – it’s not instantaneous, but certainly quick enough for posed low-light scenes. In all other areas, though, we’re looking at the S9500 all over again, with positives including assured ‘good light’ focusing and a healthy shot-to-shot rate provided you’re shooting JPEGs. When it comes to playback things are a little less satisfactory, with a noticeable delay scrolling between images and the battery life using regular AA cells is disappointing – a set of copper-top Duracells expired at around the 200 frame mark, which may be OK for a day’s shoot, but NiMH rechargeables or Energiser Lithium cells are preferrable.
Thats the review that made me buy one.
some nice shot's there,have you got any other lens for your 9600,ive seen some on the bay and was wondering if there any good.
Can i also ask what batteries you use in your camera ?
I know it take's 4 aa's but just wondering what make you use.
Many thanks
I have a circular polariser and a UV filter for it, but no other lenses, not quite sure why you ask as it is attached and cannot be changed, you mean the add on things?
Using Uniross 2700mah batteries, they seem to last a decent amount of time.
hi,i know it's a fixed lens but just seen some other add on's for the camera and was wondering what they were for.
im getting my camera today and have just brought some energizer normal batteries to get me going until i found out what the best batteries to use.
Best batteries are Uniross Hybrios or similar. They hold charge much better than normal nimh. They have a lower rating than top nimh (2100 compared to 2700) but ignore that. The feedback on them on forums such as dpreview is that real charge is similar in use. The great advantage is the length of time they hold charge as you really want 2 sets, one in the camera and one spare. With the new hbrio type the spare set will hold charge and be full when you change instead of losing lots of charge like nimh.
Don't worry about add on lenses yet.
Another good brand of slow discharge niMH batteries are Eneloop. I use them in my flashgun and they last for ages, and like the Hybrio brand mentioned, they dont lose much charge when not in use, which makes having a spare set handy as they are ready to go when you need them.
Thanks for the reply's about the batteries chaps.
Is there a place you buy them from or do you just go to the bay and get them from there.
Whats the best and cheapest place to get them from ?
I need the charger and 12 batteries of the batteries you recommend.
Just shop around the cheapest supplier. I did see them going quite cheap in a high street electronics shop not long ago. Also they can be recharged in chargers for nimh batteries so if you already have a charger you don't need to buy a new one. Four in a 9600 will last a fair time (assuming it is similar to the 6500), I just have a set in use and one set spare.
Hope this doesn't break competitors rules as OcUK don't sell batteries.
The eneloop ones can be had here
http://www.component-shop.co.uk/html/instant.html
and the hybrio one can be had here
http://www.batterylogic.co.uk/hybrio-multi-usage-longlife-aa-rechargeable-battery.asp
Both are pretty much the same in performance, I went for the eneloop cos they are a snazzy white color :P
edit:
make sure to get the 2000-2100maH rated ones, rather than the lower capacity 800maH
Thanks for the links.
Good price's on the battery logic site.
added 2 pack's of the hybrio battery's(x8)2 battery case's,charger...and it came to £30 which is pretty good price imo.
many thanks for the info about the battery's.
