fujitsu ESPRIMO_P956 upgrading help
9 Jul 2021
uk
hi all
first time posting so be gentle.i appoligise for my spelling and grammer im dylexic and just cand write propperly.
right i got this pc from work a couple of years ago and all the parts in it so its cost me nothing other then the gpu at the time running os on an ssd. storage on normal hdds its been fine all this time no problems other then the psu. which at the time i got around by putting a 500w server psu in it mainly as i have a lot of storage internally so didnt want to be out of juce.
im running a gtx 1050 ti which has done its job for what i need but as with typical fujitsu psu 16 pin no extra psu cable for a bigger gpu connector that is problem number 1 i want to upgrade the psu or wire in a cable to run a better gpu.
i have a unsused tx1320 server that has 2 600w hot plug psus in it with the cage and gubbins but again no extra cable for gpu. any ideas on that or anyone know of a psu that has extra cableing that would fit? did think about an atx adapter but the standby votage is wrong 11v for fujisu if i remeber correctly or something like that that stopped standard atx psus from running and back at work a mate had to wire in an extra psu for that line and drop the voltage to get it running. id rather not do that.
problem 2. the cpu again nothing wrong with it but its 6th gen and with the new windows coming out i really dont want to buy a whole new pc for it im kinda attached to this one lol. so i need to know what cpu can i put in this thing. iv looked and to be honest the cpu upgrading just goes over my head so would you know what ones are compatable to get. if you could give me a list i would be greatfull please.
chipset intel q170 i belive. socket lga1151
im not after a mega gaming pc but would like to upgrade this one so its going for a bit more longer with the new windows and better games that are coming out.
so any help would be appreciated.
below are all the specs i could pull up to help.
Processor Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz 3.41 GHz
Installed RAM 64.0 GB (63.8 GB usable) (ddr4)
Device ID B4DAB1C4-759F-4706-A503-9635BA1E4BD4
Product ID 00330-50421-36340-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
OS Name Microsoft Windows 10 Pro
Version 10.0.19043 Build 19043
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-5RHA8DU
System Manufacturer FUJITSU
System Model ESPRIMO_P956
System Type x64-based PC
System SKU S26361-Kxxx-Vyyy
Processor Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz, 3408 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date FUJITSU // American Megatrends Inc. V5.0.0.11 R1.29.0 for D3402-A1x, 27/01/2020
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer FUJITSU
BaseBoard Product D3402-A1
BaseBoard Version S26361-D3402-A1
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United Kingdom
Hardware Abstraction Layer Version = "10.0.19041.1081"
Username DESKTOP-5RHA8DU\lee
Time Zone GMT Summer Time
Installed Physical Memory (RAM) 64.0 GB
Total Physical Memory 63.8 GB
Available Physical Memory 58.6 GB
Total Virtual Memory 73.3 GB
Available Virtual Memory 65.9 GB
Page File Space 9.50 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualisation-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: PCR7 binding is not supported, Hardware Security Test Interface failed and the device is not Modern Standby, Un-allowed DMA-capable bus/device(s) detected
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Does the 2 server psus have any 4 pin molex connectors as you could get a 4 pin molex to a 6 pin pcie cable , although not ideal.
unfortunatly not the cage is again a 16 pin which is annoying can i splice in to the 16 pin and add a molex connector i can do that easy enough if i know the pin out i need? its been a while since i did any work on a pc i used to fix electronics for a living but for the life of me cant remember half of it.
I have no idea just be careful , 4 pin molex is only rated a 54w, 6 pin pcie is 75w and 8 pin at 150w max.
Do your research.
yes indeed will have a dig about on that again aside from that what about the cpu i honestly cant figure out what one is compatable ideally 8th gen or higher any idea?
i can modify it no problem already did to fit the 500w server psu i stucjk in ther that is fairly large . but its adapting the atx socket to the 16 pin thats the problem if i can get that figured out then ill do it fine i know i have to drop the standby voltage to 11v with a diode but im lost with the pin outs need a good wireing drawing so i can adapt it. asthetics do not bother me as long as its functional im happy my last pc i built was a optiplex 790 smalll form factor that i stuck in a standard atx case with a massive psu and extra ports looked like something from the crytstal maze coputer section lol but woked like a charm.
There isn't any value in changing the CPU as its already one of the best that can be used on that platform.
thats what i saw but was wondering with the new gens that have come out if there was an i7 that would fit it so that i didnt have to worry about windows 11 issues as from what iv read it wont support 6th gen and everything els in my sytem reports as compatable just the cpu?
failing all of that a new mobo that is atx that will fit my ram so can then get a atx psu and new cpu but i was hoping to avoid that as might as well just buy a new pc?
just the cpu then if i cant fit a newer gen in there thtas compatable then ill have to eather stick with windows 10 or buy a new rig for 11.
While some server PCs might use pretty standard PSUs, many server PSUs are incompatible with desktop PCs with multiple differences.
Usually at least connectors and available voltages are different.
And those big brand/supermarket PCs are often designed for one time use and very unupgradable using not desktop standard parts.
In general motherboard support is limited with crippled BIOS containing only minimal settings being common.
Though in this case standard consumer retail sale motherboard wouldn't make any difference to lack of upgradability:
Courtesy of Intel's greed there are three different sockets for same rebranded architecture CPUs.
("10th" gen is literally fourth rebranding of 6th gen Skylake)
And without hacked BIOS no LGA1151 board will take any CPU which would be anykind upgrade from low end quad core.
For comparison consoles have 8 core CPU with 7 cores dedicated exclusively for the game.
