Fujitsu Siemens Pocket LOOX 610
22 Oct 2002
Essex, innit?
I have been offered a Fujitsu Siemens Pocket LOOX 610 for free (well in exchange for a 6 disc stereo that I've taken out of my new car and was going to chuck away).
Can this be used as a GPS in my car?
What else do I need to get it to work?
Is it any good?
Thanks
Is it any good?
Thanks
Its got BT so you could use a BT GPS receiver, or a CF GPS unit. Cant use an SD GPS as the SD slot isnt SDIO. You would also need routing software like Tomtom5 or Mapopolis. The cpu seems reasonable so it would do the job quite well.
