23 Oct 2011 at 22:20 #1 Biohazard Biohazard Permabanned Joined 29 Aug 2003 Posts 31,330 are there any still made? I've tried googling and find acrylic ones from years ago but not much these days? Want a boxish case for going on a shelf.
23 Oct 2011 at 22:23 #2 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland expensive but... http://www.overclockers.co.uk/showproduct.php?prodid=CA-000-XS&groupid=701&catid=7&subcat=2112 http://www.overclockers.co.uk/productlist.php?groupid=701&catid=7&subid=2113
24 Oct 2011 at 01:10 #3 Hyburnate Hyburnate Soldato Joined 29 Jul 2011 Posts 15,696 Location Near Northants / MK KiiYzOo said: expensive but... http://www.overclockers.co.uk/showproduct.php?prodid=CA-000-XS&groupid=701&catid=7&subcat=2112 http://www.overclockers.co.uk/productlist.php?groupid=701&catid=7&subid=2113 Click to expand... he said to put on his shelf .
24 Oct 2011 at 14:30 #4 dcsarge dcsarge Soldato Joined 19 Dec 2008 Posts 2,746 Location Nowhere How about an Antec Skeleton as a base frame and then build your own box around it?
25 Oct 2011 at 00:39 #5 Marvin Marvin Soldato Joined 27 Nov 2009 Posts 3,869 Location Maidstone, Kent dcsarge said: How about an Antec Skeleton as a base frame and then build your own box around it? Click to expand... Probably the best bet to be honest. Most ATX cubes are humongous. Possible exceptions being: Danger Den Torture Rack with lid Mountain Mods H2GO Danger Den Water Box Mountain Mods Bob Slay None are cheap though.
25 Oct 2011 at 12:05 #6 Hyburnate Hyburnate Soldato Joined 29 Jul 2011 Posts 15,696 Location Near Northants / MK Why not go down to micro-atx then they are easier to find
25 Oct 2011 at 13:38 #7 dcsarge dcsarge Soldato Joined 19 Dec 2008 Posts 2,746 Location Nowhere LEGO! That way you can build it to just the right size
25 Oct 2011 at 15:46 #8 .Max. .Max. Associate Joined 23 Mar 2011 Posts 232 Location Oxford That is so Awesome, I was close to buying a new case just then.. But now I'm off to order some lego!
