Full ATX MCE Case Advice
11 Apr 2003
Notts
Hi all, im looking for a MCE style case, that will take:
DFI Lanparty Socket 939, stock cooler, and a full size 1900XT graphics card + 3 hard drives, my budget is around £50, is it possible?
squiffy said:
SilverStone LC17B (Black) Aluminum Front & SECC Body Desktop case (w/o PSU)
£58 inc.
Need IR remote & receiver, about £20.
Does it take a normal size PSU? Have a 550W one I would like to use, Would also be a good idea to use the MCE remote and receiver?
squiffy said:
It takes standard size ATX PSU by the look of it.
http://www.silverstonetek.com/products/lc17/lc17.html
As for remote control, just bung the dongle in spare USB port.
http://www.overclockers.co.uk/showproduct.php?prodid=SW-009-MS&groupid=33&catid=20&subcat=
If you're building a HTPC you need remote control.
Well I have my hardware:
X1900XTX 512MB
X2 3800+
160GB HDD x 2, 120GB x1
1GB PC4200 Ram
Just need the case, remote, and such, gonna use it for movies, music, tv, arcade like games and such :D
Ditch those three hard drives, and have one big one (noise and heat reduction)
Ditch ATI X1900XT for ATI X300 -passive, less heat and zero noise.
Purely from HTPC viewpoint of course.
Well its gonna be in the same room as my main PC So im not so woried about the noise, and bit tight on cash hence why Im using a mix match of hdds :D
