Full Backup Solution
18 Sep 2012
After a number of issues with my computer, I really need to get a proper backup solution in place.
Current backup solutions in place:
  • SyncBak: for backing up a second internal hard drive with personal stuff and photos.
  • Windows Restore: to protect against OS corruption.
However, I don't have anything in place to protect against the primary hard drive or motherboard physcially failing.
I've heard about creating a system image to duplicate the entire drive, but I have a few questions and would really appreciate any insight or alternative advice with this please.
1. Will it also backup all the programs and what's in them, such as email drafts saved, login creditentials etc such as Steam, VR setups etc?
2. Will this system image work if I have to change the motherboard, as presumably many of the drivers are specific to the motherboard?
Many thanks in advance
Windows Backup should work fine.
Thanks. I'm guessing Windows 11 provides basic motherboard drivers. I just wasn't sure if doing so from a backup based on a different motherboard would confuse and corrupt it all? Or are the Win 11 basic motherboard drivers generic and work across all brands and models?
Windows should automagically sort itself out, though it would be prudent to have a USB stick with drivers.
Good idea. I've been looking into the Windows built in one, but I think I came across a Microsoft online forum type mod saying that it was a depreciated service and it would be better to use a third party one. I think I'll look into this Veeam Agent one.
Thanks all, appreciated.
Windows 11 backup and restore has been updated as time has gone on, it does the job just fine.
I only use its system image creation part though to create a VHD image during my monthly backup run of the whole OS drive. The VHD can then be browsed like an Explorer folder later if you want to pull off single files etc, otherwise Windows backup can use the VHD to restore the fill drive image in the event of a disaster, this incudes boot sector and so on. It is effectively a clone of the whole drive and whatever else you select. It takes around an hour or less to create a backup of my 2TB drive which is half full and the way I do it is create the VHD to another internal SSD, then back up that SSD to an external backups SSD each month using FreeFileSync so only new and changed files are backed up, with removed files deleted off the backup automatically.
Make sure the disk is not encrypted, I'd just copy paste the data to an external USB drive.. At lest you know that it all copied over, so many times I've seen automatic backups only copy part of the data or stop working and no one noticed.. And do you really need a system backup? A clean install only take 5 mins once you have the usb
Hasleo Backup Suite V5.4 is free backup app will let you backup with system clone that will work on new motherboard without need to reinstall Windows, apps and drivers.
Thanks all, really appreciate all this as it's an area I have very little knowledge in.
Thanks for this, very reassuing. An internal and then to external is what I had in mind, the first being for speed and the latter as a redundancy. Presumably I could use my SyncBack for the external just as you use FreeFileSync?
I don't think anything is encrypted, I've certainly not done so.
Awesome thanks, I'll have a look at this.
A proper backup solution should include offsite as well
I've currently got two external drives that I keep offsite for my current personal stuff and family photos, althuogh I don't keep them as up-to-date as I should. I did look into using my website hosting server, but they freaked out after the first backup because of the amount of data lol I'm not overly keen to use the cloud.
Yup, I've used other sync tools before settling on FFS which has a UI and features that I liked a bit more.
Bear in mind too that off site backup can be expensive vs keeping a locally secured drive. You can put an 8TB SSD in a fire proof box for example when not being used.
With the way things are online these days, data breaches and stuff, I've always preferred local external drive backups in this two stage process.
Would anyone be able to advice on the rough size I'd need? I'm guessing similar to what is being used on my C: drive, but I'm not sure if there's compression involved with the image backup?
Logically you want the same size drive as teh source drive or bigger, as I backup two drives onto one my external backup is 8TB, even though my files drive is 8TB, it is only half full and it will be a long time before I need a bigger external drive once the files drive gets close to full.
Thanks!
windows usually encrypts your drive without telling you (it's a new thing in the last year or 2, when you link your PC to a microsoft account)
Yeah I really hate how it tries very hard to force you to use an email/microsoft account when installing Windows.
Do you know how I would find out if it's encrypted or not? Although maybe I could stop being lazy and Google it for myself, but figured it is still good to have here as reference for others.
search for bitlocker in the windows start menu and you should get manager bitlocker it will show you there if its on or off
