- 24 Feb 2009
- Teesside
Hey. Im currently collecting parts for my second loop, a GPU only one. I only really have the block left to buy and was set on a VGA only one originally as I planned to upgrade my card soon. However, Ive already upgraded to a GTX275 and plan on keeping that for a while, so dont really need the ability to easily swap blocks bewteen cards now.
Anyway, I was basically wondering what would be best? Get an EK Supreme VGA block along with some heatsinks like these or these. Id probably end up spending around £45 that way.
Or would I be better off getting an EK full cover block? Found one for £70 so it costs more, but will it offer better performance at all? Im only using a single TFC Xchanger rad so would using a full cover block add too much heat to the loop?
So yea, generally asking which you would recommend, what would give the best performance (I intend to overclock slightly as well).
Cheers
Cheers
