full motion or up/down wall mount for Sony W829?
14 Feb 2004
London
Why does this seem to be an impossible task?
I'm looking for a full motion or up/down (don't care about swivel or tilt) flush wall mount for my 55inch w829... everytime i find one it says it's only available for small TV's like up to 40" or 15kgs.
Is there something wrong with my search term? Do full motion or up/down motion wall mounts for 55" + TV's exist?
It would be great if it also has a shelf or compartment for a wall mounted soundbar but this is icing on the cake - if it doesnt I'll just fit a shelf to put the soundbar on.
Why do you need to raise and lower the TV?
multiple reasons:
1. not sure what most comfortable height will be until we get a sofa
2. multiple data socket and other wall sockets currently at the level of the TV so it will need adjusting when we start plugging things in
multiple reasons:
The seated height from the sofa won't vary that much. So it's unlikely that you're going to need say a metre of TV height adjustment. In fact there isn't one exact height relative to the sofa height that will be "correct" since people vary in height over a greater range than sofa seating height varies. .
It's entirely possible to come up with a rough figure for suggested TV height, but whatever height you decide on will be a compromise to accommodate all the people viewing. Any standard TV bracket will off you the ability to adjust the final position of the TV by a good 20-30 cms via adjusting where the bracket rails attach to the TV.
Finally, sockets.... That's why they make extension cables.
