Hi Guys
We now have stock of the full range of Ozone Gaming Gear headsets.
the brand offers exceptional features at superb price points.
none of the Ozone headset range is particularly expensive and given the features on offer, they represent epic value.
The main selling point of the full ozone range is the durability and rugged design of each product. They are built to last!
take a look at the whole range.
Ozone Gaming Gear Attack Stereo Gaming Headset @ £16.98 inc VAT
ATTACK is quick and efficient, is the gaming headset that came to win. Its compact leather cushions fit on your head with a light and tight feeling. The adjustable headband is built in soft materials for comfort during intense use. The revolutionary microphone allows setting the headset as a gaming intercom device or as a regular music and multimedia headphones.
The mini jack 3.5mm connector makes it easy to use and compatible with most portable music players. ATTACK uses braided cables to add quality and durability, and its in-line controller with volume control and microphone mute functions is the handy interface for this complete ATTACK.
- Comfort leather cushions
- Ergonomic Adaptive headband
- Revolution Adjustable mic
- Mini jack 3.5mm connection
- Easy In-line Controller
Microphone
- Mic Dimensions: ø6.0 x 5.0mm
- Directivity: Omnidirectional
- Impedance: ?2.2K?
- SPL: -38dB±3dB
Headphones
- Driver Dimensions: ø40mm
- Impedance: 32?
- Frequency: Response 15~25kHz
- Sensitivity (SPL): 98dB±3dB
General
- Cord Length: 2.5m
- Plug: 3.5mm jack x2 (headphones + mic)
- Net Weight: 258g
Only £16.98 inc VAT.
ORDER NOW
Ozone Gaming Gear Attack Snow Limited Edition Headset @ £20.99 inc VAT
LIMITED EDITION
If Attack is quick and efficient, ATTACK SNOW is quick, efficient, and white. If you want to become the best, you need to keep your head cool! These are some of the advantages for which Attack Snow could become the perfect headset for you.
It features leather cushions which fit on your head with a light and soft tight feeling. An adjustable headband has been built in soft materials as we know how important comfort becomes when you play hard. The revolution microphone in-line controller allows switching from gaming intercom device to regular music and multimedia headphones. Also, the mini jack 3.5mm connector gives you the easiest way to use it with most devices. It keeps your head cool when you're pointing your enemies. Attack Snow, presents a lot of features to help you improve your gaming skills.
Features
Only £20.99 inc VAT.
ORDER NOW
Ozone Gaming Gear Spark Stereo Gaming Headset @ £24.98 inc VAT
SPARK is the beginning of Ozone stereo gaming headsets with standard 3.5mm jack connection, for versatile use. You can use it as a gaming headset or together with your music and multimedia players. With an high quality sound range it can become the perfect partner for in game action. The large sized ear cups and the leather slim cushions makes it very comfortable even during prolonged periods of use. The adjustable headband and the revolution mic. allows a perfect fit to your head and a customized adjustment of your headset.
SPARK's foldable design makes very convenient to carry it out saving space and protecting it. . Spark uses braided cables to add quality and durability, and includes an in-line controller that allows you to adjust the volume and turn the mic on or off. Ozone design turns your gaming environment in a stylish universe.
- Comfort earcups
- Adjustable headband
- Revolution mic
- In-line controller
- Stereo Sound
- Foldable Design
Microphone
- Mic Dimensions: 6.0 x 5.0mm
- Impedance: 2.2K
- SPL: -45dB±3dB
Headphones
- Driver Dimensions: ø50mm
- Impedance: 32?
- Frequency Response; 20~20kHz
- Sensitivity (SPL): 100dB±3dB
General
- Cord Length: 2.5m
- Net Weight: 342g
Only £24.98 inc VAT.
ORDER NOW
Ozone Gaming Gear Onda ST Stereo Gaming Headset @ £26.99 inc VAT
There are certain situations when you need to keep your head cool, and concentrate without pressure. Ozone Onda ST has been designed for that purpose. Onda ST is the evolution of the Ozone stereo headsets. This professional headset will overcome your expectations about stereo earphones. With a high quality sound range and a detachable microphone that catch all the details it will become a great partner for your hardest battles. This headset has been designed to provide comfort for the longest gaming sessions. Thanks to the ultraconfortable headband and its soft cushions you will ever feel it as a second skin.
Features
- High quality 40 mm speakers
- Ultracomfortable headband
- Soft cushions for long gaming sessions
- Inline audio controller
- High quality detachable microphone
- Low weight ergonomic design
Microphone
Impedance: less than or equal to 2.2KOhms
Sensitivity: -54dB +/- 3dB
Headphones
Driver Dimensions: 40mm
Impedance: 32 ohms
Frequency Response: 20 ~ 20kHz
Sensitivity (SPL): 117dB +/- 4dB
General
Cord Length: 250 +/- 10 cm
Plug: 3.5 mm jack (headphones + mic)
Net Weight: 310g
Only £26.99 inc VAT.
ORDER NOW
Ozone Gaming Gear Oxid USB Gamers Advanced Gaming Headset @ £29.99 inc VAT
When you're in the real game every second is precious and every sound counts. Ozone OXID is the ultimate solution in gaming headsets for advanced users. The closed earphones let you concentrate on the game and the included mic follows your intuition when you need to get in full cooperation with your team mates.
Ozone OXID gives you full control at the tips of your fingers with its unique inline controller. This controller give you access to a volume wheel, a mute switch, a subwoofer switch, a multimedia control and a microphone on/off switch. Ozone OXID has been engineered to fit your head in comfort during hard gaming sessions. The adjustable headband is made of soft materials for comfort and its perforated material makes it right for long time use - no heat, no slip, just gaming.
Microphone
- Mic Dimensions: ø6.0 x 2.8mm
- Impedance: 2.2K
- SPL: -38dB±3dB
Headphones
- Impedance: 32
- Frequency Response: 20~20kHz
- Sensitivity (SPL): 96dB±3dB
General
- Cord Length: 3.0m
- Plug: USB
- Net Weight: 310g
- Compatible with Microsoft® Windows® XP / Vista / 7 / Mac OS X
Only £29.99 inc VAT.
ORDER NOW
Ozone Gaming Gear Onda 3HX Universal Gaming Headset, PS3/ XBOX 360/ PC @ £41.99 inc VAT
Onda 3HX has been the result of a long design process. At Ozone we set a very ambitious goal, designing a headphone set that cover the needs of all gamers. To achieve this we needed to create stylish headphones with high-quality audio (input and output) very comfortable and with a fair price. But also we needed to create a headset compatible with all videogames platforms.
And after a long design and engineering process this is what we´ve done. Onda features high quality 40 mm speakers, ultracomfortable headband, soft cushions for long gaming sessions, and a high quality detachable microphone. To make it useful we added an in-line controller to allow you to change easily the volume and some other features. But also we made Onda 3HX compatible with PC, X-box 360 and Playstation 3. Do you need something else? What about a red backlighted logo to make it look awsome?
Anyone, anywhere, Onda.
Compatible with Microsoft Xbox 360, Sony Playstation 3 & PC
Feature
- High Quality 40 mm speakers
- Ozone backlighted logo
- Built-in soundcard
Only £41.99 inc VAT.
ORDER NOW
Ozone Gaming Gear Strato EVO 5.1 Gaming Headset @ £58.99 inc VAT
Turn the lights off...the battle begins.
Survival of the fittest is the law of the battlefield. You must evolve, be ready and armed with the right gear to survive. OZONE is devoted to satisfy the most demanding gamers, that's why our engineers have developed a new and evolved STRATOevo to relieve Strato, our best headset till the moment.
This new headset, apart from giving you the best of Strato, brings you to the next evolutionary level of gaming. Its unbelievable 5.1 surround sound and a highly customizable software allows you to control with surgical precision each detail on the sounds coming out of the game. STRATO evo features some improvements related to comfort ability and sound quality that will definitely improve your gaming experiences:
Third Generation of Multi Channel Audio Standards
Six independent physical audio units to achieve the most amazing 5.1 surround sound; With built-in with VIB2 inertial vibration unit.
New Headset Chamber
Thinner and with a wider cavity for improved sound quality.
New LED Microphone Design
Larger MIC unit, with more sensitivity and noise cancelling technology for an improved user experience.New design features a red LED indicator for MIC function status.
New Innovative Earcup Design
Larger earcups to fit your ears and designed for an improved comfort.
Easily Interchangeable Earcups
Two different pairs (leather and cloth) included.
Improved Headband Design
With aluminum alloy beam for improved performance and comfort
Lighter and More Compact
Built with last generation material to reduce 30grs. It folds into half of the original volume.
Only £58.99 inc VAT.
ORDER NOW
Microphone
- Impedance: ?2.2K?
- SPL: -38dB±3dB
Headphones
- Impedance: 32?
General
- Cord Length: 2.5m
- Net Weight: 258g
ORDER NOW
LIMITED EDITION
Features
ORDER NOW
- Comfort earcups
- Revolution mic
- Stereo Sound
- Foldable Design
Microphone
- Impedance: 2.2K
- SPL: -45dB±3dB
Headphones
- Impedance: 32?
General
- Cord Length: 2.5m
- Net Weight: 342g
ORDER NOW
Features
Microphone
Headphones
Impedance: 32 ohms
General
Net Weight: 310g
ORDER NOW
Microphone
- Impedance: 2.2K
- SPL: -38dB±3dB
Headphones
- Impedance: 32
General
- Cord Length: 3.0m
- Plug: USB
- Net Weight: 310g
ORDER NOW
Feature
ORDER NOW
New Headset Chamber
ORDER NOW
