25 Sep 2006 at 15:31 #1 Zip Zip Soldato Joined 26 Jun 2005 Posts 20,224 Location Australia Ive got the game here and its yet to be installed. Anyone here play it and is it worth installing? Any hints and tips? Thanks
25 Sep 2006 at 15:44 #2 MNuTz MNuTz Suspended Joined 17 Mar 2004 Posts 4,934 Location Market Drayton, Salop yes its worth playing, as for hints and tips, just take your time playing the tutorials and you should be fine!
25 Sep 2006 at 16:01 #3 Zip Zip Soldato OP Joined 26 Jun 2005 Posts 20,224 Location Australia Thanks Ill make sure to install it once i get the Format done Does anyone have any Screen shots of it?
25 Sep 2006 at 16:12 #4 ots3go ots3go Associate Joined 15 Jan 2005 Posts 2,452 Location Leiden - NL Tips.... patience Will install it when I get home and take a few screenies if you can wait a couple of hours.
25 Sep 2006 at 16:20 #5 MNuTz MNuTz Suspended Joined 17 Mar 2004 Posts 4,934 Location Market Drayton, Salop just do a picture search on google, there is a few on there among the ten hammers stuff
25 Sep 2006 at 16:22 #6 Zip Zip Soldato OP Joined 26 Jun 2005 Posts 20,224 Location Australia ots3go said: Tips.... patience Will install it when I get home and take a few screenies if you can wait a couple of hours. Click to expand... Yep ive got a few days to wait You Many hours to take them
25 Sep 2006 at 17:14 #7 Arsey Arsey Associate Joined 28 Feb 2006 Posts 2,497 Location Wimbledon Original or Ten Hammers? Original is good on COOP, but not played 10 hammers
25 Sep 2006 at 17:18 #8 Zip Zip Soldato OP Joined 26 Jun 2005 Posts 20,224 Location Australia Arsey said: Original or Ten Hammers? Original is good on COOP, but not played 10 hammers Click to expand... Its the Original
25 Sep 2006 at 23:14 #9 Arsey Arsey Associate Joined 28 Feb 2006 Posts 2,497 Location Wimbledon Get yourself a partner and do some coop then
26 Sep 2006 at 17:37 #11 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 33,002 Location Rutland I found it all a bit repetitive, suppress....flank....kill the baddies...repeat....
27 Sep 2006 at 06:15 #12 Zip Zip Soldato OP Joined 26 Jun 2005 Posts 20,224 Location Australia thanks for the pictures and sugesting Co-op, Ill have to install it soon
27 Sep 2006 at 11:23 #13 Pug Pug Soldato Joined 20 Oct 2002 Posts 5,184 Location Over there... played it on XBox - single player, and thoroughly enjoyed it... not too tricky, but challenging enough...
