Full system
8 Mar 2011
I am after buying a PC tower of Overclockers. What would you recommend?
I do a lot of streaming and photo / video editing along with Kodi. I do play the odd COD game etc as well. I will be using a 55" 4k Samsung TV as my monitor.
My budget is £900. Thanks
What about this build?
Case Zalman Z11 Plus HF1 Midi-Tower
Motherboard Gigabyte GA-Z170X-Gaming 3 Intel
Processor Intel Core i5-6600K
Memory Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-19200C14 2400MHz
CPU Cooler Corsair Hydro H55 Quiet Liquid CPU Cooler
Solid State Drive Samsung 500GB 850 EVO
Graphics Card Asus GeForce GTX 970 DirectCU II OC Strix 4096MB
Power Supply Cougar CMD 600W Digital '80 Plus Bronze
£1,002.94
if you drop down to an i7 4790k or even the i5 4690k you'll still get a cracking system within budget.. the 6600k has only got a 12% increase over the 4690k but being honest you'll never notice it within games.
do you need an operating system? would you want prebuilt or you happy to build?
Prebuilt without o/s. Also i what about an i7 4770k?
Thanks for replying
the 4770k is the older version of the 4790k it runs a bit hotter as far as im aware.
what will be the main use of the machine? if its just for gaming you wont go wrong with a i5 4690k. that way you could spend a bit extra on the gpu.
give me you're thoughts?
EDIT: just spotted you do video editing... are you could also go for an AMD 9590 or 8350 as they have the extra cores which would be used for video editing
