Fully synthetic oils - are they all mostly the same?
Yes they vary greatly both in spec and price, either use the spec your manufacturer requires or use something to Mercedes 229.5/229.51 or the VW 507 spec which are high spec oils. I use 229.51 in my Mondeo since the Ford spec is quite poor and it feels warm and fuzzy to know my turbo's bathing in the highest quality amber nectar :P
I think most people should be more concerned with whether it actually has the right amount of oil in vs being a very specific type.
Some cars with dpf can be picky I've heard though.
It's really not
Seconded.
"Oil" just means it's a non-polar viscous liquid that's not thick enough to be a grease.
There's a fair degree of variation in the definition of synthetic oils; all the way from remanufactured mineral oils (catalytic hydrogenation), to blended esthers.
Seconded.
There's a wealth of different additives used depending on the uses too
So if Tescos did a value range of oil, you would put that in your motor?
If the SAE temp and viscosity ranges were the recommended ones and the type of oil, synthetic etc. was correct then yes.
Notwithstanding I do not like Tesco much, but in principle I would buy an oil on price and judgement that it would do the job.
My car has done 120,000 miles and has had main dealer servicing throughout so the majority of oil used has been bulk Honda synthetic. The 1 litre top up between servicing is down to me and has not been Honda oil.
