Fun and games trying to find a replacement car battery
Man of Honour
13 Oct 2006
UPDATE: I've ordered a Varta Silver 019 battery and just hoping for the best - no reason really why it shouldn't work - all the sites using registration data bring up the wrong battery and from reading elsewhere a 019 is definitely preferable for the model than the 096.
Been trying to find a replacement battery for my Nissan Navara but so far pretty meh experience:
Tayna only has one direct suggestion and that is hugely under the current spec and I want to atleast match ideally beat the current battery (95ah, 850 cca). Weirdly if I use a numberplate search on other sites that act as a store front for Tayna (for instance Amazon) I get a fair range of suggestions but they are all very average batteries.
ECP - even with discounts the batteries they list as suitable for my model are massively expensive compared to anywhere else and mostly they are selling one model lower/older variant of the model at a far higher price.
Halfords - like ECP seem to be selling a slightly lower/older version at a moderately higher price.
RAC - quite expensive though do 1-2 similar batteries to what I currently have but can't find anything that actually matches or beats via numberplate search.
Several other sites have very poor recommendations for my model/reg that are far below the power level that would be ideal.
Most of these sites have higher spec batteries that I think should work fine but often they say not suited to my vehicle :s AFAIK as long as the battery dimensions fit and the amperage is sufficient or higher for my vehicle there shouldn't be any issue but I don't have a lot of experience with car batteries directly. I'm tempted to see what my main dealer has to offer.
EDIT: I think the confusion is these sites are speccing for a normal Nissan D40 2.5dCi but the Outlaw model I have isn't the same as the other D40s. Bit confused here but I think I currently have a 019 battery fitted while all the sites, etc. are listing 096. More confusingly if I type in the serial on the battery I have it comes back as a Varta L5 promotive 155ah which definitely isn't what I have fitted though it is a Varta L5 series.
You know I had a similar situation with the battery on my Volvo as the thing has the stupid stop start on it (which I never use) turned out, believe it or not, going to Volvo and getting a genuine Volvo battery ended up cheaper than a third party.
I found that carparts4less off of ebay seem to undercut most (ecp / carprats4less direct with vouchers, & rac for sure)
https://www.ebay.co.uk/itm/S5-019-C...30cca-12V-Electrical-Bosch-S5013/292339097348 ~£130
and would even wait for next ebay deal
edit : do we put in sealed bids by personal email ?
I ended up going for the Varta version of that battery - think it is the same things just different label - for about £15 cheaper.
It has never been complicated in the past - I've just entered registration, ignored the obvious rubbish brands and found exact replacement at a reasonable price. A lot of places seem to ignore the V6 Outlaw version of the Navara even exists and treat it like the regular version but there are a lot of differences.
yes I've always been paying for Bosch name, but a varta with the same 5 year guarantee sounds just as good .. for 10% less
8 years into my current one .. but I don't stress them.
Did you try looking up on the Yuasa Website
https://www.yuasa.co.uk/
No I hadn't - oddly they actually suggest 019 batteries for my number plate - weird because I thought all these sites used the same data - they also have more detailed info on the vehicle than other sites come back with.
I've already bought a battery now and they are a bit more expensive than I can get Varta/Bosch elsewhere anyhow.
