function help php
19 Jul 2006
PHP:
// at the top of the page
function checknumber (){
$number=$_POST['number'];
$number= ereg_replace("[^0-9]","",$number);
$length= strlen($number);
$flag = true;
 if ($length==10)
 $flag= true;
 return $flag;
 else {
 $flag=false;
 return $flag;
This logic works.
in main part of page i do
PHP:
<div id="mainblock">
<?php
checknumber ();
if ($flag==true){
echo"	value is true do something";
else{
echo" value is false	do something else";
</div>
but it echo's valuse is false do something else even if the length does equal 10
what am i doing wrong now?
TIA
You're not storing the value returned from checknumber, just calling the function, you need...
PHP:
<?php
$flag = checknumber();
if ($flag == true) {
   echo "value is true do something";
else {
   echo "value is false do something else";
</div>
or easier...
PHP:
<?php
if (checknumber()) {
else {
</div>
Also, not required, but just some info in case you didn't know, in your function I'd check if $_POST['number'] is set, otherwise PHP will display an E_NOTICE; eg.
PHP:
<?php
function checknumber() {
  if (!empty($_POST['number'])) {
    $number = ereg_replace("[^0-9]","", $_POST['number']);
    return (bool) (strlen($number) == 10);
  return false;
Thanks PaulM
functions look really good and useful and i dont think im using them to there full use.
I seam to write them and then not get the output i want and end up writing more lines of code rather than your simple
if (checknumber())
solution
Thanks PaulM
if (checknumber())
solution
I think you can even repolace the lines:
PHP:
$flag= true;
 return $flag;
with:
PHP:
return true
and the same for when flag is false.
Also as already said, pass it a parameter instead of hardwiring it to use a POST variable. Then it becomes reusable and not locked down to that particular variable.
