Furmark Results ?
  • Thread starter Thread starter unknownsoldier64
  • Start date Start date
unknownsoldier64
unknownsoldier64
ATI 5770
3.2 ghz AMD x4
Asus Formular 111 board
4 GB of Ram
And i am geting 3601 on furmark ?
looking at other peoples results mine are pritty poor considering the setup ?
Can anyone advise please thanks
Anthony.
# Score: 3601 o3Marks
# Submitted by quakeanthony @ December 11 2009, 3:20 pm
# App Version: oZone3D.Net_FurMark_v1.7.0_Build_Jul 3 2009_at_09:19:42
# Renderer: ATI Radeon HD 5700 Series
# Number of Active GPUs: 1
# Graphics Drivers: Catalyst 09.11 - 8.671-091104a-091523C-ATI 11-4-2009
# GPU Temperatures (start/end):48°C / 71°C
# Bench Duration: 60 sec.
# Resolution: 1280 x 1024
# MSAA samples: 2
# Window Mode: fullscreen
# CPU: AMD Phenomtm II X4 955 Processor
# CPU Speed: 3210 MHz
# Operating System: Windows XP build 2600 Service Pack 3
Exactly how are these cards cooler than the 4000 series? I've never seen my 4890s go above 50C under load and they idle at 30-40C
Derail the thread? I commented on something you posted. I didn't realise that wasn't how forums worked, sorry.
Well maybe if you would have said that score is quite low or the score is average , and then posted your querey i wouldnt be bothered but as you just answered my question with a question about temp and your gfx card not the benchmark score its kinda going off topic in my eyes ...
cheers .
Well i don't actually know much about furmark or what scores you should be getting. If the score is low for the card and you're getting such high temperatures i'd say you've got a duff card.
Though, like i said, i don't actually know anything about it.
Never go above 50C load, now that's BS if I have ever heard it.
Anyway ATI can detect furmark in the drivers (even if you rename the exe) so I would run 3dmark vantage and then have a look at your max.
That is a bit high at stock though. At 1000/1400 1.24v with the blower style cooler I reach 79C.
ATI 5770
3.2 ghz AMD x4
4 GB of Ram
Anthony.
i have athlon64 x2 3800+ running at 2.4 Ghz
2gig ddr pc3200 ram
sapphire 4870 512mb
with the exact same setting as u i was getting
[ SCORE: 4420 o3Marks ] - Time: 60000 ms
Resolution: 1280x1024 (FS) - MSAA: 2X
GPU Clock:500MHz - Memory Clock:900MHz
AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
2400 MHz
u must be joking right never go above 50 deg under load try turning it on then. my 4870 puts out 81 degs at 100% load unless your a moron and have your fan on 100% all the time
Well obviously you know about the temperatures i get from my cards better than i do. Cheers for the info, I mean having owned a 4870 you must know everything about my 4890s and can tell me i'm bull****ting.
4870 and 4890 are pretty much the same card though :p
I had a 4870 and it got hotter than 50deg playing games.
Fine. I don't doubt that's true but he's basically either calling me a liar or a moron. I'm neither of which, i don't see why i'd make this up.
Under load i set the fan at 50% and it doesn't ever go over 50C. Even when i'm playing Crysis on very high.
Nah, XFX. It doesn't have the standard cooler though, that's probably got a lot to do with it. It's this card:
LINK UR EXACT CARD TO OCUK IF THEY SELL THEM
go run furmark at high res and see what temp it puts out then 50 or less and i would say it could have a faulty sensor they should be running high 60's to mid 70's under full load
