Further memory tweaking
19 Oct 2002
Chester - a.k.a Gh0sTf@cE
Hi again
So I've now managed to get these tight timings stable
Is there anything out of sync that you can see with my timings? Do certain timings have to relate to another for example?
And what timings should I aim for on which?
Thanks for taking your time to help me in advance
Ok thanks, currently testing
What would you use to test stability as running prime blend for hours at a time is becoming increasingly tedious...
Well that seemed easier than I thought it would be...
Ran AIDA64 stability test for 2hrs and Prime blend for an hour and seems stable...?
Anything else I can tweak please fella?
Looking good winston, i'll have another pop at mine at the weekend. I see your pll is at 1.9v does that help overall stabillity?
Does your bios show all ram settings if so can you post pics?
Yeah seems to help make mine more stable, most say 1.65 but mine seems to like it higher
Will upload you some pics tomorrow fella, as pc's currently being stressed, for a change, lol
Appreciate it thx, i'm giving up on pushing frequency to far, i just dont have the knowledge to make them work and to be more beneficial or my hardware is not up to the task.
Do you or 8Pack know what the (think its??) ddr ref voltage is for got 4 of them so presume its the 4 ram slots?
Edit
Here they are
Yes run em at -35 and aim for 2900 plus tighter!!!! with 1.75v.
You are in a good position now. Try going tCKE 5 and tWCL 7. May or may not work!!! Try tuning the two third level timings you have at 4 down also. Those at 5 leave as they are needed for stability. Again this may or may not work but is worth trying.
Ii have gone back to the drawing board at the mo, last beta bios was not great for me.
Currently primming with a x45 multi and 102 bclk giving
4590 and 2448
Vcore is at 1.336, all ram timings are currently on auto
Pll 1.6v
Io 1.2450v
SA 0.9850v
PCH 1.0685v
Dram 1.655v
Now when i start to tighten up and it goes unstable, is it just the dram voltage i touch if the above is fully stable??
I'd up the Dram to 1.68 to start with
What timings is it listing as AUTO as a few of them might be too tight already...
plenty of room for tweaking, just want to get system stable first, another 20 mins then i can start tweaking unless it throws up an error!!
Edit, nearly forgot, just updated your trust, thx bud
