*** Further Sapphire Goodness ***
Suspended
18 Oct 2002
OcUK HQ
A Couple of arrivals today. More great deals for Sapphire.
*** Sapphire ATI Radeon HD 4870 2048MB GDDR5 Vapor X PCI-Express Graphics Card @ £152.98 inc VAT ***
The ATI Radeon HD 4870 Series GPUs deliver a cinematic gaming experience with unprecedented performance. Play today while preparing for tomorrow with tessellation, support for DirectX® 10.1 and scalable ATI CrossFireX™ technology. Vapor Chamber Technology is based on the same principles as heatpipe technology. A liquid coolant is vaporised at a hot surface, the resulting vapor is condensed at a cold surface then the liquid is returned to the hot surface. The recirculation process is controlled by a patented wick system. SAPPHIRE Vapor-X flattens the whole system into a slim chamber - which in the graphics application is mounted in contact with the surface of the graphics chip.
- ATI Radeon HD 4870 GPU @ 750MHz
- 2048MB GDDR5 Memory @ 3600MHz
- 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering
- PCI Express 2.0 support
- ATI CrossFireX Multi-GPU Technology
- Microsoft DirectX 10.1 support
- Shader Model 4.1
- ATI Avivo HD video and display technology
- Unified Video Decoder 2 (UVD) for Blu-ray and HD Video
- Built-in HDMI with 5.1 surround sound support
- On-chip HDCP
Only £159.99 inc VAT
ORDER NOW
*** Sapphire ATI Radeon HD 4890 Vapor-X 2048MB GDDR5 PCI-Express Graphics Card @ £190.99 inc VAT ***
The SAPPHIRE HD 4890 Vapor-X 2GB model is a SAPPHIRE original design. It has SAPPHIRE’s Vapor-X cooling module on the GPU together with a heatsink and profiled fan venting heat out of the case. With core clock speed of 870MHz and 2GB of DDR5 memory clocked at 1050MHz, this model not only has additional memory but is also quieter and significantly faster than competing products based on the standard reference design. The larger memory size and faster speeds deliver higher performance in rendering tasks and increased frame rates in games - especially at high resolutions and where complex textures are used.
- ATI Radeon HD 4890 GPU @ 870MHz
- 2048MB GDDR5 Memory @ 4200MHz
- Shader Model 4.1
- On-chip HDCP
- 2 Year Warranty
Only £190.99 inc VAT
ORDER NOW
