** Fury X & 980TI Blocks from XSPC **
rjk
rjk
Caporegime
8 Aug 2007
Finally we have our hands on these lovely blocks from XSPC, the FuryX block is a real masterpiece with some genius flow channels for actively cooled VRMs.
We have a tech labs XSPC 980TI available right now, the furyX isnt available in tech labs form just yet due to lack of availability.
XSPC Razor R9 Fury X @ £99.95 inc VAT
Full cover R9 Fury X water-block with multiport connector.
We are proud to introduce our new design for Razor GPU blocks. We have continued with the styling from our RayStorm series so you can now have a full set of matching XSPC blocks. We have also significantly improved cooling performance by reducing the fin width from 1mm to 0.5mm, this dramatically increases the surface area.
Although we have used an acrylic top for aesthetics we have a thin stainless steel plate between the copper base and the acrylic. This allows us to use LED lighting, while keeping the strength and reliability of an all metal waterblock.
The new multiport connector gives you many choices for neatly routing your tubing. We have two G1/4? ports on the front and back of the block, two on the top, plus a side port, giving 7 ports in total. The multiport connector is compatible with our new SLI flow bridge.
CNC machined copper base
0.5mm fins for high performance
Active VRM cooling
Stainless steel top
Acrylic layer with 3mm LED holes
Brushed aluminium faceplate
Dimensions: 177 x 131 x 30mm
Prepared for Crossfire with 7 G1/4? ports
Supports AMD R9 Fury X cards (AMD reference designs only)
Supplied with twin LED, mounting kit, G1/4" plugs, thermal pads and thermal paste
Only £99.95 inc VAT.
ORDER NOW
XSPC Razor GTX 980 980 Ti VGA Water Block @ £94.99 inc VAT
Full cover GTX 980 and 980 Ti Water-Block with multiport connector.
Active VRM cooling
Stainless steel top
Dimensions: 264 x 125 x 25mm
Prepared for SLI with 7 G1/4? ports
Supports Nvidia GTX 980 and 980 Ti (Nvidia reference designs only)
Only £94.99 inc VAT.
ORDER NOW
Considering the smaller size of the Fury X block you'd have thought it would be cheaper, but then as you can't actually buy a Fury X it's a moot point.
Would it be possible to do a feature in the not too distant future about relative performance of the different Tech Labs options, or at least point to some credible reviews so punters considering which option to go for have more than just the looks to help them decide?
I really want to do a block roundup myself but stock of the Fury/Fury X is so low that getting one is hard over here :(
As far as prices being similar as larger reference PCB blocks, I suspect it's to do with the time spent making this short block as well as engineering a solution to getting water into the VRMs area of that is super close to the core here.
the reason the fury block is more is because of the way it is designed.
check out the product images of it and you will see that there are two flow chambers within the same block which means the design of the block is far more complex.
