So now that I am getting mine tomorrow can some one please answer some questions?
Can you remove the fan easily? I have my own fan I want to use. Are there screw mounts in both sides of the rad?
Basically I just want to bolt the rad onto the 120mm PCIE intake fan in my case, getting rid of the AMD one. I must do this as my fan has a special sensor in place and is 4 pin PWM and controlled by my PC.
