Currently have a fury x with a Benq freesync monitor
If I go NVidia which is most likely is there anything I need to enable or disable so that my freesync monitor will work with my NVidia card (Probably 1080/1080ti)
Thanks
Why above 90.?You should be looking for a good 1080Ti to keep the FPS above 90 constantly at your resolution, to not to feel the lack of Freesync.
It'll just work like a standard monitor, you'll loose variable refresh.
Because biology.Why above 90.?
Why above 90.?
Actually I got Acer X34A and still prefer running games on my 4K oled TV (apart from fast fps shooters) at locked 60fps due to the contrast and black levels.If you have 100hz+ monitor with Freesync/Gsync, believe me, anything bellow 90 without Freesync/Gsync looks terrible, if you got used to the adaptive sync technology.
Only if you have a freesync option in the menus on the monitor. If not your good to go.Currently have a fury x with a Benq freesync monitor
Thanks
I have a BenQ XL2730Z
its 144hz
Same one here. Works like a charm with my 1080ti. Didn't even change any settings.
Yep, with the 1080Ti it will work nicely because it has the grunt power to push high fps at 2560x1440 (90+). The 1080 not :/Nice that's good to know cheers![]()
The 1080 isn't fast enough?
Damn.
