You know those 2 pin shaver adapters? I've got two pieces of computer equipment, a USB enclosure and my scanner which both come with 2 pin euro plugs that have to be used with adapters. I use a shaver adapter for that. The adapter says 1A fuse, 1A 250v mains only.
My question is, is it the input or the output written on the euro plugs that mustn't exceed 1A of the shaver adapter? The input of each euro plug is 0.4A and 0.8A, and the outputs are 1.25A and 2A. Is it safe to use these things with that shaver adapter?
