- 18 May 2010
Hi
I would appreciate some advice from anyone in the know please. We have a baby in the house now and I want to try and make the house as safe as possible.
My electrician says my fuse box doesn't have RCD protection, to achieve RCD protection which apparently prevents electric shock he gave 3 scenarios all of which have the same end result
1 - replace fuse box, can't do this because of box location will be too expensive
2 - replace individual fuse box switches with RCBO I think he said
3 - replace the master switch on the box only with RCBO
Apparently all 3 achieve the same result, if that's the case why would anyone do anything other than the cheapest option?
Also, is there any other benefits to this work or is it just to prevent electric shock? I'm confused as to why the standard switches don't do that I thought that's what they were there for!
Thanks
Thanks
