Hi all
I'm in the position of potentially moving house in the next 6 months, I know the floor plan of the house I'll be moving in to and starting to plan out all my electrical, network and general geekery needs.
At my current house I've been running a Cat5E setup including a central patch panel, switch and ports in all major rooms of the house. I wish to replicate this setup but "future proof" it as far as reasonably practicable.
I've been doing a little research and think I've settled on running a Cat6A installation to cater for future roll out of 10 Gig Ethernet whenever costs come down and equipment is commonly available.
So I have a few general questions please...
1) Do you think I'm wise in choosing Cat 6A? I know that standard Cat 6 would be fine for 10 Gig Ethernet over small runs and would be cheaper etc... I can afford the extra costs though and I'm big on making sure this is future proofed and it's a relatively big 4 bedroom detached property so the runs could get long.
Rough calcs indicate the following
a) Cat 5E = 20p per metre
b) Cat 6 = 30p per metre
c) Cat 6a = 50p per metre
2) Cat 7 cable. Should I do more research on this and keep it in mind as a viable option?
3) Should I run some fibre connections at the same time, say from the cabinet where the patch panel and router will be sited to the main office / PC / server location. If so, please could you link a suitable cable please as I know very little about fibre. My thoughts here would be to run the fibre and then whenever it takes off in the future I pay a specialist to splice the necessary ends on perhaps??
4) Would unscreened Cat6A solid cable be ok to run behind walls, from the patch panel to the RJ45 outlets? I suspect screened cables introduce complications and would need bonding to the house earth?
Thanks for your time
Mike
Mike
