Unfortunately there's no such thing as future proof in this game!
I'd start at about the 600W decent PSUs and work upwards based on whether you want modular etc.
Of course, if you wan't as much power as possible, look at the 1KW supplies, but I think these would be overkill for what you state up there, there's few machines that genuinely require that much power.
need a decent future proof psu preferably to run sli 280's, 8800gt for physx, xfi, 5 hd's, quad @ 3.6 then maybe watercooling.
Also would like a energy effecient one.
I have a OCZ stealthXtreme 600w at the moment but dont know if its going to cut it with all of the about but with one GTX280 and the 8800GT....
What you guys think ?
Energy efficiency varies with load so if its a really important factor make sure you have a realsitic view of your powerload and dont under or oversize your PSU. Big psu's will tend to be noiser as well as using more power at low loads
"Big psu's will tend to be noiser as well as using more power at low loads"
That's absolute rubbish. It depends entirely on the quality of the PSU in question, the better the PSU the quieter and the more efficient it is. Size has nothing to do with it.
You can't "oversize" a PSU either, a PSU will supply only what is needed.
Efficiency is prett much nonsense in PSU's anyway, we're only talking a few %, over a year the saving would be tiny, but it's green, it's a nice selling point, so it's hyped-up.
Nothing wrong with a more efficent PSU of course! But let's not pretend it will save the planet or kepp your leccy bill down.
I'm sorry, you're wrong.
Every PSU has a sweet spot - the point at which it's most efficient. Generally they're about 50% load (that's not accurate for all). If you have a 1200W PSU and you use 300W at load and 200W at idle then you'll not be getting much efficiency from it.
Over the course of 2-4 years life of a PSU that can account for half the cost of it.
...most modern PSUs actually stay above 80% even at very low loads.
It's simple maths, but it confuses a lot of people.
Let me explain.
70% efficiency - 30% wasted. Running at 400W load that's 120W constant waste.
85% efficiency - 15% wasted. Running at 400W load that's 60W constant waste.
Leccy is what, 10p per kWh?
So that's 60W wasted or 0.06kWH, at 10p is £0.006 per hour. £0.144 per day, £1.008 per week, £52.416 per year, and £157.248 for the 3 year life of the PSU.
Of course 70% against 85% is an unlikely comparison. But the figures show there's money in it.
