Future Proof?
TK1
TK1
28 Mar 2006
(Socket AM2) AMD Athlon™64 X2 5000+ Dual-Core CPU w/ HyperTransport Technology
Socket AM2)Asus M2N32-SLI Deluxe nForce 590 SLI MCP Chipset DDR2/800 MBoard w/ Dual 16x PCI-Express
(2x1GB) PC6400 DDR2/800 Dual Channel Memory Corsair XMS2 Xtreme Memory w/ Heat Spreader
NVIDIA GeForce 8800 GTX 768MB 16X PCI Express Video Card
250GB SATA-II 3.0Gb/s 8MB Cache 7200RPM HDD
SATA150 - Western Digital Raptor 36.7GB 10,000RPM 8MB Cache WD360GD
SONY DUAL FORMAT 18X DVD±R/±RW + CD-R/RW DRIVE DUAL LAYER
Will this sort of setup be future proof for the next 2 years? This system will be on Vista too
TK1
Change the CPU to E6600.
Motherboard change to the eVGA 680i.
Not sure if the 36GB is enough, might want to consider 74GB.
Get a Core 2 Duo system. Much, much faster than AM2.
Check the other specs, or wait for somebody to do you one. What's the budget?
What about?
(Sckt775)Intel® Core™ 2 Duo E6700 CPU @ 2.66GHz 1066FSB 2x2MB L2 Cache EM64T
Asus P5N-SLI nForce 570 SLI Chipset LGA775 Supports Core 2 Duo CPU FSB1066 DDR2/800 Mainboard w/GbLAN,USB2.0,IEEE1394&7.1Audio
Get a mobo with the Nvidia 680i chipset and an E6600. The rest is up to you, but the 8800 is very nice, good mem. Some say raptors are overkill, others can't do without them, again up to you. Also, need a good cooler, something like a tuniq tower. How are you for PSU and case?
How about something like this?
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
Leadtek GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache - OEM
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
EVGA nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
CellShock 2GB (2 x 1GB) DDR2 PC2-6400C4 800MHz Dual Channel Kit
Sub Total : £1,085.93
Shipping : £9.95
Vat : £191.78
Total : £1,287.66
After that, just choose the cooler you want (as said about the Tuniq) and Case etc.
NZXT PF-500 500Watt Power Supply
(Sckt775)Intel® Core™ 2 Duo E6600 CPU @ 2.4GHz 1066FSB 2x2MB L2 Cache EM64T
CoolerMaster Liquid CPU Cooling Fan System Kit + 2 EXTRA CASE FANS
CoolerMaster Mystique 632 Tower 420W Case
(Quad-Core Supports) EVGA nForce 680i SLI Chipset LGA775 FSB1333 DDR2 Mainboard
2GB (2x1GB) PC6400 DDR2/800 Dual Channel Memory orsair XMS2 Xtreme Memory w/ Heat Spreader
320GB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD
Any better?
Any better?
No. I'd suggest a beefier PSU. The suggested 620W Corsair is a good one.
Thanks for the replies just one thing do most of you think Intels Dual Core E6600 is better than AMD's 64 X2 5000+ Dual-Core CPU? for gaming?
