** Futureproof Cooling for 2011 **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
At OcUK we know that a cooling solution is seen by many customers as an investment. Today we are pleased to announce that our range of watercooling hardware for CPUs have been updated to include the very latest sockets.
Now you can upgrade to watercooling safe in the knowledge that your purchase will be compatible with upcoming technologies.
OcUK V6 Watercooling Kit 120 **2011 Compatible** @ £118.99 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike
Component List:
1X EK CoolStream 120.1 Radiator
High air flow and quality finish make this budget radiator a great solution.
1X XSPC 200 Bay Reservoir & Pump - Clear
A clever space saving solution that allows you to see your coolant level from your drive bays
1X EK Supreme LTX CPU Waterblock - Nickel Acetal
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
1X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fan
The most recognised performance fan for watercooling radiators.
1X Mayhems Ultra Pure H20 Watercooling Fluid
The purest water available - ensuring the best temperatures.
1X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Silver Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
By buying this kit you save £2.29 over buying the components separately.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Only £118.99 inc VAT.
ORDER NOW
OcUK V8 Watercooling Kit 240 **2011 Compatible** @ £210.98 inc VAT
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X Hardware Labs Black ICE SR-1 240 Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK DCP 4.0 Pump
A superb all round pump with a small footprint inside the case
1X EK Reservoir Combo DCP 4.0
A powerful aftermarket top and reservoir combo to ensure maximum performance from your Pump
1X EK Supreme HF CPU Waterblock - Copper Plexi
2X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish
IMPORTANT:
By buying this kit you save £8.68 over buying the components separately.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Only £210.98 inc VAT.
ORDER NOW
OcUK V12 Watercooling Kit 360 **2011 Compatible** @ £296.99 inc VAT
Component List:
1X Hardware Labs Black ICE SR-1 360 Radiator
1X 12V Alphacool Laing D5 Vario Pump 655
The best watercooling Pump on the planet. Accept no substitutes.
1X EK-D5 X-Top V2 Acetal G1/4" - Pump Top
A powerful aftermarket top to ensure maximum performance from your D5 Pump
1X XSPC Single Bay Reservoir - Multi Fascia
A high flow reservoir for your D5 providing an easy filling and draining point in your loop.
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
2X XSPC 7/16" ID [16/11mm] Clear
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
IMPORTANT:
This kit can also be upgraded with an additional VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Please ask our friendly sales team for VGA block advice.
By buying this kit you save £4.39 over buying the components separately.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Only £296.99 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme LT 120 **2011 Compatible** @ £122.99 inc VAT
EK have stepped in and solved this problem. With each EK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Ideal for first time watercooling enthusiasts and seasoned veterans alike, transform your computer system
All of these kits offer the new EK Standard EN Nickel Plating method which ensures the highest quality nickel plating finish on your water blocks.
Overclockers UK recommends the use of Distilled Water or Watercooling Fluid which is available on this web-store.
To make the kit functional, the user needs 1Litre of Coolant.
The EK-KIT H3O - Supreme LT 120 water cooling kit is basic kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme LT 120 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel 775, 1155/1156 and 1366 processors. The CPU block comes with an additional plate to allow use with AMD AM2 and AM3 sockets
Supreme LT block is one of most efficient CPU blocks (value for money) and offers very good thermal conductive performance and low restriction. Single EK-CoolStream RAD XT radiator will fit in majority of watercooling cases and will succesfully take heat out of your system. EK-DCP 2.2 pump has been also proven for some time now by water cooling community and allows adequate and optimal flow for your kit.
"EK-KIT H3O - Supreme LT 120" water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (120)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is included)
It is reccomended to use this kit for CPU cooling only
Only £122.99 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme LT 240 **2011 Compatible** @ £138.98 inc VAT
The EK-KIT H3O - Supreme LT 240 water cooling kit is a kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme LT 240 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel 775, 1155/1156 and 1366 processors. The CPU block comes with an additional plate to allow use with AMD AM2 and AM3 sockets
EK-CoolStream RAD XT (240) radiator will fit in majority of watercooling cases and will succesfully take heat out of your system (please check template of rad prior to installing in case).
EK-KIT H3O - Supreme LT 240 water cooling kit includes following items:
- EK-CoolStream RAD XT (240)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
IMPORTANT:
This kit can also be upgraded with an additional EK-VGA waterblock!
Only £138.98 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme LT 360 **2011 Compatible** @ £149.99 inc VAT
The EK-KIT H3O - Supreme LT 360 water cooling kit is a kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme LT 360 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel 775, 1155/1156 and 1366 processors. The CPU block comes with an additional plate to allow use with AMD AM2 and AM3 sockets
Supreme LT block is one of most efficient CPU blocks (value for money) and offers high thermal conductive performance and low restriction.
EK-CoolStream RAD XT (360) radiator will fit in majority of watercooling cases and will succesfully take heat out of your system (please check template of rad prior to installing in case).
EK-KIT H3O - Supreme LT 360 water cooling kit includes following items:
- EK-CoolStream RAD XT (360)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
IMPORTANT:
Kit is easy to install, use and maintain (installation manual is included).
Only £149.99 inc VAT.
ORDER NOW
EK Supreme HF CPU Waterblock - Full Nickel **2011 Compatible** @ £64.98 inc VAT
The Ultimate CPU Waterblock
After 2 successful years of EK-Supreme CPU water block, EK has released its successor. The EK-Supreme HF - Full Nickel Block is based on same concept as EK-Supreme.The base plate is made of nickel plated electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of nickel plated electrolytic copper material. Mounting plate is made of powder coated stainless steel. The EK-Supreme HF - Full Nickel cooling engine uses fin design. The water accelerates through thin jet plate channels through 49 very thin channels, which gives extreme cooling surface. The copper base is also very thin, which gives very short distance for temperature to transfer from CPU to water.
Blocks main improvements are:
- better flow up to 50% higher flow compared or EK-Supreme
- better cooling performance
Enclosed in the box:
- EK-Supreme HF - Full Nickel water block
- 4 different jet plates + 1 blank
- Universal supported mounting plates:
o Intel: 775, 1366, 1156, xeon
o AMD: AM2, AM2+, AM3, 939, 754, opteron
- Universal CPU retention backplate
- Thermal grease Arctic Cooling MX-2 (2g)
Supported sockets:
Processor compatibility:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Only £64.98 inc VAT.
ORDER NOW
EK Supreme HF CPU Waterblock - Nickel Plexi **2011 Compatible** @ £55.79 inc VAT
EK-Supreme HF (HF stands for High Flow; revised version) is a universal CPU socket waterblock designed for the most hardcore enthusiast users.
EK-Supreme HF is a direct successor of the world renown EK-Supreme waterblock launched in 2007.
It's main improvements are:
- better flow: due to improved design up to 70% higher flow compared to EK-Supreme
- better cooling performance: up to 3°C lower CPU temperatures
The EK-Supreme HF's cooling engine uses fin design. The water (coolant) accelerates through thin jet plate's channels and turbolently continues it's path through 49 very thin channels which provide extreme cooling surface area. Very thin copper base bottom wall even further improves cooling performance.
The base plate is made of electroless nickel plated (EN) electrolytic copper lapped and polished to +/- 0.0007mm flatness. The top is made of quality cast acrylic material. Mounting plate is made of black painted steel.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- EK-Supreme HF series water block
- EK-CPU Easy Mount HF mounting mechanism
- Universal Intel LGA mounting plate (preinstalled)
- Additional universal AMD Socket mounting plate
- TIM / thermal grease: Arctic Cooling MX-4 (1.6g)
Please note:
- Due to superior nickel plating method and corrosion resistance, the waterblock may loose brightness over time and become of a bit duller tone.
- With introduction of new easy mount mechanism, additional jet plates were removed from box. Despite this EKWB made sure the best performing jet plate is being preinstalled.
Only £55.79 inc VAT.
ORDER NOW
EK Supreme HF CPU Waterblock - Nickel Acetal **2011 Compatible** @ £53.99 inc VAT
The base plate is made of electroless nickel plated (EN) electrolytic copper lapped and polished to +/- 0.0007mm flatness. The top is made of quality POM acetal material. Mounting plate is made of black painted steel.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Please note:
Only £53.99 inc VAT.
ORDER NOW
Which one gives you the most bang for your buck?
The OCUK versions or the EK?
the EK are designed to offer performance and offer excellent VFM
the V6 ocuk kit is designed to outperform the 120 EK kit
however, the V8 and V12 OcUK kits are designed to provide out and out performance without compromise.
if you want the best WC gear money can buy, the V8 and V12 kits are for you.
I do love how you copied the blurb and just changed the company name :p
Good looking kits though.
I wrote the blurb so I will copy it as much as I want! :p
i think intel should have anticipated their delay and called it LGA 2012 :p :p :p
we don't know when its due realistically.
Did anyone else read the title and wonder why it was offering futureproof cooling for the year 2011... of which we have 3 months left
Don't really need to read into the year really?
I think everyone knows what the op is getting at.
Water-cooling for the now rigs and future rigs. In most cases a new mounting clip is all that is needed for new cpus and boards.
