Fuzzy Screen = dead GPU?
8 Jun 2004
Essex
Hi
Built a new pc about 2 months ago and had everything running nicely - turn on pc this morning and as it booted up the screen just went fuzzy - is the graphics card dead?
Using a HIS Radeon HD 3870 X2 with an ASUS P5K Premium mobo
Thanks for any help
S
hi
thanks for help - i've tried reseating the card / checked cables / but with no success. My big problem is that I cant even go into the BIOS because as soon as I boot the screen is just fuzzy - basically the picture you get if you were to pull out the aerial on a tv.
I'll try the component connection once I've found my extension lead- the one from provided from HIS is about 4 inches long!
cheers
s
MMm
just attached my wifes macbook and again no signal although i'm not sure if i would get one as we've never attached to an external monitor.
However - the playstation produces a picture no problem - does this therefor mean that the graphics card is broken! RMA?
cheers
S
Working now - and not sure what i did to get it back to normal - just followed some google advice.....unplug monitor / unplug dvi cables. Switched pc on and left for 2 minutes to get into windows. Power up monitor and attached dvi cables - back to normal - very very wierd
