FX-6200
1 Sep 2012
Lancashire
A few questions :)
For the FX-6200 3.8GHz not overclocked what temp range am i looking at having??
Currently:
35 to 38 idle
60 to 64 Prime95
using speedfan to measure temps, mobo shows similar results for idle
Ambient temp shows between 33 to 38. my room temperature I would estimate to be around 18c.
CPU temp can shoot up massively from 35 to 42 with only a slight load (10%) for a few seconds.
Do i need to look at putting some arctic 5 on the heatsink instead of the stock stuff??
I want to get it up to 4.2 to 4.5ghz, would i need a new heat sink?? if so can you please spec me one for under £30 :)
Currently have 3 case fans like this marked with 'x'
________________
x........X .............|
|........................X
|_PSU __________|
rear one is sucking out, side and front are blowing in.
Have a possible 6 slots for fans - 2 front, one bottom, 2 side and one rear
like so:
________________
|........X..............|
|.....................X.X
|_PSU ___X______|
one of the front ones is offset back a few cm behind the very front one.
I want to know if the setup for my fans are fine how they are, or if there is a better way to have them?
Thanks
Matt :)
Thought i might, it does stick out quite a way :)
Is the fan setup fine for my rig and are the temps suitable. not sure if i can trust my temps, 18 - 22c in room, 32c to 38c ambient. only had a laptop before so don't know a lot about ambient temps :P
Hmm download hwmonitor and use that rather than speedfan IMO
64 sounds a bit hot, IIRC you don't wana go over that. The new cooler should sort those temps out nicely.
Just read up about overclocking the FX chips before you do :D
sorry, i haven't re seated the cooler. I was saying that maybe I haven't put the cooler on very well as my temps are high in speedfan and hwmonitor
