I built my new PC (specs in sig), and I ditched the stock cooler for a CoolerMaster Seidon 120V version 2 water loop. They get great reviews for the price (£35) and it's running practically silently even with the included fan. I plugged the rad fan into CPU_FAN on the mobo, though it's set to 100% all the time in the BIOS anyway. The block/pump is plugged into CHASSIS_FAN1 to be safe and make sure it gets 100% power all the time (without the BIOS trying to throttle it for any reason).
Our house is a really warm new build, and I mean to the point room temps hit 30oC on a normal summer day with doors/windows open and no heating etc. That said I'm still thinking this is running a tad on the warm side compared to everyone's reviews etc. I'm running the chip at stock atm (I do plan to OC once cooling is sorted), and the ASUS smart power save/CPU throttling/Cool n Quiet is enabled. As such the chip goes to 100%/4.0GHz under load but throttles down cores and speeds when idle.
Idle: 33oC on boot or sitting idle in BIOS. Currently 43oC with a browser open and a game paused in the background with 3% CPU usage. [ETA back to 36oC now Steam is closed]
Load: 64oC after 15 minutes of Prime95 on all 8 cores.
Every review of this cooler that I've read said they're getting idles in the low 20s (probably impossible in this house to be fair) with fully loaded torture test highs of 35-40oC. With that in mind my temps at stock seem rather too high with no real room to even attempt an OC. I did do a quick and dirty 'max performance' automatic OC in the BIOS and it was running at 4.6GHz at less than stock volts (1.34v) which leads me to think this chip will be sweet once cooling is sorted.
The only thing that's niggling me (and hence this thread) is that when installing the cooler the TIM quickly 'shot out' of the little tube. Rather than play 'hunt more isopropyl alcohol and another lint free cloth' I just shrugged and fitted the cooler anyway. I'm not talking a huge amount here, btw! Perhaps a bit less than a 5p coin's worth, or a rather large pea if you will. I'm just wondering if the TIM is too thick and it's causing a bit of a thermal block. Is it really worth me taking the cooler block off and reseating it with less TIM (or something other than the 'free' Cooler Master stuff that came with the kit)?
TL;DR - My all in one water cooling kit is nice, but my FX-8350 is hitting mid 60s under heavy load. Is it my warm house or do I need to stop being lazy and reseat the cooler after ordering some proper TIM?
